They do seem to run a little richer on boost than OEM, I suspect they have a slightly different airflow/Voltage curve. Only the modified cars seem to display the rich running, at least it's better than lean mixtures I guess. Did you reset the ecu before fitting it Josh?
The problem is the 'replacement' Nissan AFM's run much the same as these, and only last a short time in comparison, (something gets damaged inside at full noise for some reason.) I have yet to hear of a failure from these aftermarket afm's, and the price is much more reasonable.
Gives you a good reason to tune the car Josh. :P
Yes a good tune is next on the list once I get a ecu. Was thinking wolf 3d(to give us another ecu option) or greddy emanage ultimate(already tried and tested). Found when I was giving it a little using triptonic once I went from say 1st to 2nd gear it kinda stalled/stuttered.
Well, I bought the red S1 off ebay. Price was OK for S1 Dayz with electric leather. Duco is sh#t but does not make it go or stop. Motor was advertised as stuffed, and it is. Compression test was my worst Chrissie present 3,5 & 6 50psi. So out with the motor and it looks like an RB30/25, same as the Sil is the way to go.
So my new year of Deeper in Debt continues. One would think at my age I would know better But then I am a Nissan Man.
Happy SAFE motoring for all for 2014..
Took the HKS pod filter out and put the factory air box back in with a Greddy high flow panel filter. Hopefully it will be a bit cooler than the pod filter and if I was to get pulled over, it isn't a defect.
Have you got a cold air deflector? That is supposed to help also.
Yeah, I have that. Kept all the stock parts just in case. Although it is a PITA carrying this stuff around when you get posted around the country every few years.
Hmmmm looks like your going to need a 4wd sump adapter and oil pick up for that mission
Hmmmm looks like your going to need a 4wd sump adapter and oil pick up for that mission And a lot of dosh.LOL
My Nismo son is doing the Sil Rb30/25 so he does the hard yards and I learn from him for a change. I have been looking at a better oil pump system
for my other RS4 Auto. It has an FFP and a pod and it runs a bit too hot and gets the gurgles I have an oil temp gauge and it gets to 120 when pushed up Henri Robert Drive.. I am looking at an oil cooler, but with a remote oil filter and an oil cooler I think I will need a much better oil pumping system. First I will go like Hanso and refit the stock air box and the cold air deflector. Mrs66 will appreciate the lowering of the induction noise.
Hugh have you put a bigger transfluid cooler on the auto RS4? If it is still routed through the bottom of the radiator that should help. I presume you are using a good synthetic oil! I had a remote filter system but gave up on looking for a place to put it so just got a sandwich plate where I can screw the filter on as its not too hard to do under the FFP.
And what have I done to my Stagea lately? Finally fitted the stock rear wing I bought ages ago, got my under mirror rust cut out and will paint shortly. I got tired of buying cheap and nasty wheels for the track and thought why don't I use my lightweight forged TE37s and bought some Direzzas to try. For the street I got a set of 18 x 8in wheels (ex Nissan GT coupe SE) which actually fit ok. I seem to have lost the ability to paste links on here (anyone else or is it my computer?) so pics will have to wait.
Also removed the knock-off Aerocatches which lasted less than 6 months and installed the much superior genuine article.
(BTW was having a number of problems with this site - unable to paste links etc. Just uninstalled IE11 and reverted to IE10 - all seems to be fixed)
"KiwiRS4T" watch out the heads of the bolts on the bonnet pins will rust out with rain, didn't have a problem washing my car but after it rained they left nice rust lines all down my bonnet :(
No worries have already replaced with stainless!
Tried to rationalise that it's just a car and was not worth commiting murder over because my mother-in-law didn't even notice she'd clipped another car with it pulling out of a car park. Nice little dent right on the crease above the driver's front wheel arch and scuffed up paint on the front bumper.
Mother-in-law is now banished to driving only the Commodore battle wagon which, every time it gets damaged, only elicits a "whatevs bro" from me.
You ought to see my two Stags. None of my doing.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
