Threw my new LED reversing lights in today; BIG difference.
These are the ones I bought.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&rd=1&item=360781669151&ssPageName=STRK:MEAFB:IT
Also gave the headlights a good clean & seal with some Juice sealer. Wish I could still get this stuff.
is it just a single globe per side? As mine is a cold pack having only one reverse light an extra bit of light wouldn't go a miss
huge difference dale, easy to change?
Pretty easy; took about 30 min.
I got the link to the globes from another member on here, but I can't find his post/how to.
I seeza crank brothers sticker :yes:
Yup. Eggbeaters. :cheers:
Yeah, single globe each side.
You could always bridge the wiring across from the other side if you wanted both on?
  • Like 1
Yeah I have thought about that, wouldn't mind having the same lights both sides.
yea cold pack has a tint red on right..
does it pop out? or a is one whole section?
i always get people saying I've got a reverse light out :wacko:
Yeah; the whole assembly would need to be replaced; you can't just pop out the red centre of the light.
All I ever get is: "Let me out; it's really dark in here, and the cable ties are cutting my wrists"... :rolleyes:
  • Like 2
Big service day today on the Stagea. Decided to give it some love, since while it's been washed and cleaned regularly, I've just been doing the oil and filter recently.
So, did an oil and filter change using nissan filter, and GW Synx6000. Put synthetic nulon 75w90 in the front and rear diffs, and some nulon synthetic in the transfer case.
While under the back, I noticed it's been driving round without a rear sway bar for quite some time.... :/
It's suffered the dreaded upgrade sway bar, snap bracket syndrome. Anyway, I got my hands on some upgrade steel brackets that Daleo made a while back and put the rear bar back together! Needless to say, it's a bit nicer handling now.... Lol!
So M35 owners with upgraded swaybars, get under your car and CHECK your brackets!!!
  • Like 3
Nice job Alex. When will you upgrading to the new murano when it comes out? Hahahah :-)
Edited by Howaitonaito
Didn't even bite at the murano joke.
There is a Fx30d and Fx50 near my house. They're about the size of the new Jeep Cherokees that are everywhere. But look so much "in your face" than the Jeep.
Started an oil and filter change very late yesterday, first time on this car. The jack and tools all looked like they'd never been used, it was a shame to put a mark them but my trolley jack is holidaying with my sister-in-law. In fact, everything on this car is (or was) so damn clean I feel sorry for it having to do family duties with us. When we got it last June it even still had the factory plastic film over the sill plates in the back, now they've been pulled off by little hands and replaced with chocolate stains on the upholstery.
Wasn't entirely sure where to put the axle stands, at first I went for the chassis rail inboard from the front jacking points but I wasn't happy with the creaking noises as I lowered the jack so I moved them to just near where the LCAs bolt to the subframe, as close as possible to the edge of the undertray. Seemed ok there but I must confess I kept checking them to ensure the metal wasn't ripping. Anyone got a better spot to use?
Also, 4.8 litres of engine oil in a PNM35 right? I did the Commodore (VS V6) earlier in the day and there was definitely more that came out of the Stag.
Edited by Hertz Donut
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
