Thanks mate, I'm happy. Even on the run in tune the car was brutal, I can't wait to drive it as it is now :)
Edit
Oh, I have babied the box to the nth degree, haven't even launched on it yet. Power has just proved too much, I guess you never know :@
Sorry if I have missed it, what turbo?
I can't remember turbo specs, do you mean front side .63? I'd have to check, but it's normal front and rear housing sizes, 0.63 front, 0.82 rear? Something like that. Am performance exhaust manifold and stock intake Mani.
Edited by stageaharts
I bought a second hand one from an S1 ages ago but just never got around to fitting it. Apparently the diaphragm?? in the original one was folded up and wasn't dropping back where it should. So good to get rid of that confounded noise. Andrew @ ASR fitted it, it was pretty simple afaik.
Sealed the paint with some protech paint shield.
Stripped the rear, ready for a big clean and leather/vynal protection. Once the rear is done. I will do the front.
Pulled apart my gtr gauges, cleaned, re sprayed the insides and made the needles red.
Put in a safc neo.
I think I will be spraying the rims duplicolor bronze. I've been procrastinating about it for months though.
Ove the last week I've replaced my timing belt with a gates racing belt (noisy and regretting it), had my rotors machined, bought some qfm hpx pads, installed new radiator, replaced valve cover seals, replaced dump pipe gasket and installed new o2 sensor. I've pulled my front left cv shaft out as well going to take it to be rebuilt Monday and need to adjustable my coilovers.
reinstalled my rebuilt s tune suspension, omg it's great to drive, now to get the rears rebuilt
Nice work mate, was this s tune suspension specifically made for the 260 or was it the 33gtr spec?
I had a strong fuel smell in the cabin and upon checking the engine bay, a hose connected to the fuel rail had decided to sprout a pin sized fuel leak. Lucky I got to it quick, but it was a bastard of a job as there is just nowhere near enough room to fit a thick hose of that length.
Installed daleo intake pipe and front chassis brace today. Thanks #@Daleo for working on the car and getting it all sorted. Now just to line up jetwreck and DVS JEZ so we can get the adaptronic ECU and injectors etc installed and we will be all systems go. But loving the changes todays work made.
  • Like 1
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
