A little bit going on this week; had a new mirror painted to replace the damaged passenger side one (thanks Iain!); while I was at it also had my painter colour code the headlight eyebrows that I've had sitting in a drawer for almost a year now (thanks Mark!).
I don't mind the look, but I'm going to wait until after my mate details the car before I decide whether they're going on. This should be happening within the next few weeks.
Off to grab a new set of tyres later this week, and I'll finally be fitting my camber/toe bolts to minimise some of the rear tyre wear.
Also about time I did a diff oil change; not that impressed with my last LSD oil choice; does anyone have a recommendation?
I was either going to try the Nulon; http://www.nulon.com.au/products/Gear_and_Differential_Oils/Full_Synthetic_80W-140_Heavy_Duty_Limited_Slip_Differential_Oil/#.VAXOk_na7Lk
Or Castrol Syntrax Limited Slip 75W-140.
Any other oils I should be looking at?
I would use the Castrol, just because that's what I've been recommended through award gearbox.
They weren't very positive about the Nulon product, however that was more to do with how the product reacts to excessive heat. I've got some nulon in the open diff in the stagea, it hasn't blown up yet... Lol however I dumped it out of the 180.
  • Like 1
What a bargain! Where from?
from fle bay mate. They are dirty as he'll need a good scrub down and condition but other than that all is perfect need a resistor on the passenger side seat for the airbag plug and just need to open up the seat belt buckle and shave down the inside latch as are seat belt cards are thicker than the 350z's then all is a charm heated switches work as does the electronic forward back adjustments just the up and down are now manual but no biggie. You score a nice little side pockets on the seat wich now catches my phone when I fall out my pocket, it use to just slide under the seat and would be a pita to find. ;-)
  • Like 2
My biggest question is "where are the damn pics!"
  • Like 2
Mate very nice actually hold in in well wich was the main reason I wanted to try as with the stock seats if you take a corner fast and hard I'd end up on the passenger side 8-) the sit lower as well the passage is really low though to low infact so spacers are needed icon real the peddles perfectly just allowed a nice fit!
Got my car back on Friday after the exhaust wheel tried to make an escape a few weeks back.
Turbo was sent off to Hypergear for a Hiflow, just the smaller "G1" profile.
More bad news, exhaust was on it's way out. Cat in the dump was pretty stuffed and rust was starting to eat the rest (the rear section was pretty bad). So some presents from Scott were in order.
And a Blitz Nur Touring cat back to finish it. Selected mostly because of the time frame, it's nice and quiet which I wanted so it worked out nicely.
While it was in having this done I also had the cam cover gaskets done, the passenger side was pissing oil everywhere and apparently had a ton of sealant around it.
Big thanks goes to R&D Mechanical for doing the work, excellent work and very helpful. And a big thanks to Scott for fabricating the dump and front pipe and getting them too me very quickly and Stao at Hypergear for hiflowing the turbo.
  • Like 4
Good work! Dyno chart?
Did my second oil change on my PNM35 over the weekend, happy to say it hasn't used a single drop of oil in a bit over 3 months. That was Penrite HPR10 which I discovered had been rerated (wtf?) to a 10W50, so I found some 5W30 on sale over the weekend, I thought I'd try it and see if there's any noticeable difference in fuel economy or performance.
Meanwhile the Commodore only had 2.5 litres left in it over the same period and had spent most of that time sitting still...sigh.
Not much new with my stagea.
Decided to paint my wheels gloss black instead of satin black, which i thinks a lot better.
was also considering getting a new rear bar, was thinking dolphin but i dunno. i have a tow var for the stag as i use it to tow our bikes etc so unsure at the moment.
Had a life f**king moment when car wouldn't kick over this morning... Tried to start it twice but wouldn't happen.
Thought straight away to look at the battery and BAM!
So did the usual "stick ur finger in the hole", there isn't anymore water but it needs a serious clean in there.
Gave my headlights a bit of a restore with the Turtle Wax kit.
Now the cracks show up real good!
So I thought I would cover some up with my home made, sheet aluminium eyelids.
My 4 year old daughter says they make the car look cranky! Win!
Painted using Supercheap Auto's Colour Spec paint.
Not a bad match, might even have a go at my roo damage unless someone has a red front left door and fender they don't need?
  • Like 2
feel like making some more eyelids mate? ;-)
  • Like 1
Well, hit the key in the Dayz and it started first kick. It has been a long haul since 8/12/2013 when she arrived on a trailer with a blown motor.
I have converted to RWD.
There are still a few things to get. A radiator and shroud. And a windscreen. They will come soon.
Can not explain how stoked my son and I were when it started first kick.
  • Like 1
A bit too time consuming, might be a bit quicker second time around but don't think I could do them any cheaper than the plastic ones you can get.
Glad you like them though.
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
