A little bit going on this week; had a new mirror painted to replace the damaged passenger side one (thanks Iain!); while I was at it also had my painter colour code the headlight eyebrows that I've had sitting in a drawer for almost a year now (thanks Mark!).
I don't mind the look, but I'm going to wait until after my mate details the car before I decide whether they're going on. This should be happening within the next few weeks.
Off to grab a new set of tyres later this week, and I'll finally be fitting my camber/toe bolts to minimise some of the rear tyre wear.
Also about time I did a diff oil change; not that impressed with my last LSD oil choice; does anyone have a recommendation?
I was either going to try the Nulon; http://www.nulon.com.au/products/Gear_and_Differential_Oils/Full_Synthetic_80W-140_Heavy_Duty_Limited_Slip_Differential_Oil/#.VAXOk_na7Lk
Or Castrol Syntrax Limited Slip 75W-140.
Any other oils I should be looking at?
I would use the Castrol, just because that's what I've been recommended through award gearbox.
They weren't very positive about the Nulon product, however that was more to do with how the product reacts to excessive heat. I've got some nulon in the open diff in the stagea, it hasn't blown up yet... Lol however I dumped it out of the 180.
  • Like 1
What a bargain! Where from?
from fle bay mate. They are dirty as he'll need a good scrub down and condition but other than that all is perfect need a resistor on the passenger side seat for the airbag plug and just need to open up the seat belt buckle and shave down the inside latch as are seat belt cards are thicker than the 350z's then all is a charm heated switches work as does the electronic forward back adjustments just the up and down are now manual but no biggie. You score a nice little side pockets on the seat wich now catches my phone when I fall out my pocket, it use to just slide under the seat and would be a pita to find. ;-)
  • Like 2
My biggest question is "where are the damn pics!"
  • Like 2
Mate very nice actually hold in in well wich was the main reason I wanted to try as with the stock seats if you take a corner fast and hard I'd end up on the passenger side 8-) the sit lower as well the passage is really low though to low infact so spacers are needed icon real the peddles perfectly just allowed a nice fit!
Got my car back on Friday after the exhaust wheel tried to make an escape a few weeks back.
Turbo was sent off to Hypergear for a Hiflow, just the smaller "G1" profile.
More bad news, exhaust was on it's way out. Cat in the dump was pretty stuffed and rust was starting to eat the rest (the rear section was pretty bad). So some presents from Scott were in order.
And a Blitz Nur Touring cat back to finish it. Selected mostly because of the time frame, it's nice and quiet which I wanted so it worked out nicely.
While it was in having this done I also had the cam cover gaskets done, the passenger side was pissing oil everywhere and apparently had a ton of sealant around it.
Big thanks goes to R&D Mechanical for doing the work, excellent work and very helpful. And a big thanks to Scott for fabricating the dump and front pipe and getting them too me very quickly and Stao at Hypergear for hiflowing the turbo.
  • Like 4
Good work! Dyno chart?
Did my second oil change on my PNM35 over the weekend, happy to say it hasn't used a single drop of oil in a bit over 3 months. That was Penrite HPR10 which I discovered had been rerated (wtf?) to a 10W50, so I found some 5W30 on sale over the weekend, I thought I'd try it and see if there's any noticeable difference in fuel economy or performance.
Meanwhile the Commodore only had 2.5 litres left in it over the same period and had spent most of that time sitting still...sigh.
Not much new with my stagea.
Decided to paint my wheels gloss black instead of satin black, which i thinks a lot better.
was also considering getting a new rear bar, was thinking dolphin but i dunno. i have a tow var for the stag as i use it to tow our bikes etc so unsure at the moment.
Had a life f**king moment when car wouldn't kick over this morning... Tried to start it twice but wouldn't happen.
Thought straight away to look at the battery and BAM!
So did the usual "stick ur finger in the hole", there isn't anymore water but it needs a serious clean in there.
Gave my headlights a bit of a restore with the Turtle Wax kit.
Now the cracks show up real good!
So I thought I would cover some up with my home made, sheet aluminium eyelids.
My 4 year old daughter says they make the car look cranky! Win!
Painted using Supercheap Auto's Colour Spec paint.
Not a bad match, might even have a go at my roo damage unless someone has a red front left door and fender they don't need?
  • Like 2
feel like making some more eyelids mate? ;-)
  • Like 1
Well, hit the key in the Dayz and it started first kick. It has been a long haul since 8/12/2013 when she arrived on a trailer with a blown motor.
I have converted to RWD.
There are still a few things to get. A radiator and shroud. And a windscreen. They will come soon.
Can not explain how stoked my son and I were when it started first kick.
  • Like 1
A bit too time consuming, might be a bit quicker second time around but don't think I could do them any cheaper than the plastic ones you can get.
Glad you like them though.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
