Fark, no good; hopefully it's fallen against a closed valve, otherwise you're in trouble. I'm assuming this happened with the upper plenum removed?
If you know which port it went down, and you still can't reach it; removing the lower plenum may allow you better access.
sorry, wrong wording.
no, in front down onto the pulleys and belts.
engine still unopened.
looked for a solid 45 mins with a torch.
not under the car or on the underside cover.
still nowhere to be seen.
hopefully won't drop or jump up into the pulleys when its going.
yep, magnet definitely on my shopping list
Edited by conan7772
I dropped a nut (steady on...) in the engine bay of my Commodore a couple of years ago while I had the intake manifold off and the valley exposed. No idea where it went but the car still hasn't died. WHY WON'T IT DIE? GAAAAHHHHH!!!
Car back on hoist for hopefully the last time for the handbrake cable and a few small things.
Noise from the clutch gone. Seems to be a tiny noise around the cat but i will be replacing the exhaust from the dump back. Now that the auto is gone i can get something that will sit much closer to the body (less scrape yay!!)
Umm picture of Drive Shaft is all i can offer today.
Handbrake is mounted and almost finished but i didn't get a picture as the car was up on the hoist.
So really on the home stretch now. The mechanic has an S13 he is getting off defect for a customer and i can live without the M35 for another day so i'm hoping to pick it up tomorrow / Wednesday/
Stay tuned
  • Like 4
Just picked up the M35. (picture inserted for joy!!)
The mechanic has given me a link to the build on their website so i shall share
http://rdmechanicalshop.com/2015/12/22/m35manual/
Car seems to be running rich and is in desperate need of a tune. Once the holidays are over i'll get it in to have the emanage tune looked at asap.
Enjoy.
  • Like 6
Nice of the workshop to put up all the details. I reckon Scotty has already started collecting the parts. Lol;)
I'm sure Scotty already had most of the parts ready to go over a year ago :P
I think he is neck deep in ECU / Turbo stuff atm which hopefully will save me some frustration after the xmas holidays :)
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
