Winter is comming.. :)
Must install engine hose heater
had to chop a bit of air cleaner housing that may be placed in tubes
Gorilla 2 component epoxy bonding Plexiglas
last night was the first night that was frost
Edited by TukeH
  • Like 3
Looks tuff, like it's going fast without moving.
Black car, dark tint, black rims with polished lip and just the front lip and boot spoiler all works really well together.
Nice one!
2 hours ago, RSXVRider said:
I've just bought my m35 and i plan to fix up all the little issues then give her some extra bolt ons.
Ive just given it a quick polish and clean for now.
Nice one!
  • Like 1
Let's try that again (stupid ipad).
  • Like 2
5 hours ago, D-750 said:
Out of interest, what is this supposed to do?
pre warm up the car before the start
1500w heater with circulation pump
works just fine when I got to try out in the morning. 20min heating the coolant was 30 degrees before heating 9 degrees
Not yet ;)
Not yet ;)
Most euro cars come with this standard right? I had it in my E53 x5.
17 hours ago, yuma said:
Had a lapse in concentration on the way home from work last night. emoji24.png
Ugh, had a similar thing happen in a shopping centre car park last Thursday - except it was another driver's lapse in concentration whilst I was sitting in my parking space!
On another note, installed the modified Nismo front bar (had to accommodate the front cameras) and Dolphin grill. Also decided to put a C34 double unicorn in the grill to finish it off :)
96fcb310-c50f-4c28-89d6-2470d63cb1fd_zps
EDIT: Yes, I am aware that is a dirty car with a poor quality phone pic.
Edited by iamhe77
  • Like 2
On another note, installed the modified Nismo front bar (had to accommodate the front cameras) and Dolphin grill. Also decided to put a C34 double unicorn in the grill to finish it off [emoji4]
Man that's schmick..... interesting idea with the cameras.
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
