Got the battery replaced in the remote. No more green flashing key symbol on the cluster and the return of the inane joy of unlocking the car from 20 metres away. So joy.
  • Like 1
Just getting the car back on the road after a long period of rebuild and decided to replace the craptastic factory gauges in my 260RS with something a little more accurate and informative...
Left to right: oil pressure & oil temp, boost & fuel pressure, voltage & water temp
  • Like 3
well i got my nm35 back from my mates garage after about 10 weeks. it now has the first uk built highflow turbo fitted & some new bc's coilovers fitted. as it was in the garage my rad got a leak in the fillerneck so had to get one from a nice lad on here. & tomorrow im off wheel shopping.
  • Like 1
Was bored and instead of working the long list of things to do/maintain the stag, i threw it on the Dyno instead to see if it's running fine, not lean as i got Impul Ecu in it now ........
Confirm it's all good, still running Rich as but better than lean i guess.
Dyno in 3rd gear, have 2 pre-run to make sure everything is safe, 3rd run is the power run for fun.
Was going to run in 4th gear but the gear box was heating up so we scrapped that and so now i really have to get off my ass to fit the trans-oil cooler.
Drill out a broken bolt in the intake manifold, replaced with high tensile grade 12.9.
Clean out the throttle body while at it, did play around with the butterfly and lucky enough, the idle is still fine, didn't have to do a re-set.
  • Like 1
So some of you (most of you from Facebook lol) probably know that the stagea was involved in a crash about a week ago.
IMG_1486364535.793506.thumb.jpg.85651443
Damage was as follows:
IMG_1486364589.983151.thumb.jpg.915a97a4
IMG_1486364620.205857.thumb.jpg.c4a49b11
IMG_1486364638.310276.thumb.jpg.d1f9c061
IMG_1486364662.884735.thumb.jpg.df29364b
IMG_1486364780.568453.thumb.jpg.450a80f0
IMG_1486364819.884065.thumb.jpg.9cfe38eb
Honestly not too bad damage for how it was hit, I'd consider myself lucky lol
Today I got some parts (thanks Liam!)
IMG_1486364708.766300.thumb.jpg.dcbae32c
IMG_1486364721.410057.thumb.jpg.da8d1a5e
While the door isn't in pearl white, silvers good enough for now..
I'm going to most likely respray the car in the future anyway.
Here's hoping I can get this subframe in and the old one out ASAP
  • Like 3
previously posted pics of LED High beam install, had my guy put in some LED fogs while I was out of town a few weeks back, no install pics just in action
Fogs with headlights off (just the daytime running light inside each headlight housing)
All of the lights (factory low beams, LED fogs and LED high beams)
  • Like 2
So it's been a pretty successful few weeks or how ever long its been lol. I'm going to try and do this in chronological order but dunno how easy that will be. This will also consist of lots and lots of photos so I apologise lol
First off, I swapped the door over. Only thing is that the inside door handle wasn't working and now after about a week with the door on the outside one isn't working... rip. Lucky I have a donor door :P
The ding still needs to be removed and painted.. got quoted $1200 which just about killed me... so dunno what i'm gonna do there, door still seals so maybe I can live with it till I can get it done and the money bank has some dough. The silver door just gives the car personality right?!?!?
Annnddd the solid Hilux to carry the parts lol
Now. The goodie. Subframe removal and putting the new subframe together but not in,
Considering my uncle and I didn't really have much to go off for directions besides the quick google and got the base stuff figured out we just went straight into it. Didn't run into any issues sides the handbrake cable cover thing getting pulled out and the metal bit getting a bit bent around the edge, but we aren't too sure if we did that or if it had happened from the crash.
IMG_3242.thumb.JPG.0523164503a26052fb056375ecd06a0c.JPGIMG_3243.thumb.JPG.dc18295488523a99764dba25fd3f9091.JPGIMG_3244.thumb.JPG.8d015bcaa8a31c4a39f38f69582cf729.JPGIMG_3245.thumb.JPG.ef25093648244a50080a12ebb1586c02.JPGIMG_3248.thumb.JPG.275cf1d343578a850bdaefbb0b17a3f4.JPGIMG_3253.thumb.JPG.c541806c874f2d12af800234cc572fcf.JPGIMG_3259.thumb.JPG.a0e42e6e75c0630082a863bffe78908d.JPGIMG_3261.thumb.JPG.d95fe773d47e9c12b4d537e816f57e73.JPGIMG_3264.thumb.JPG.49a262e02da8956fd927f90cd78b3c69.JPGIMG_3266.thumb.JPG.61cb1efed4cc3a5d6ce7fad5436e3c62.JPGIMG_3275.thumb.JPG.d89733f74d7e169525707445a048d08b.JPGIMG_3276.thumb.JPG.b0baec7e6265e34c41c470fe5f8af00a.JPGIMG_3289.thumb.JPG.4f9869e33883809fcb6c4a7bc501a7ca.JPGIMG_3299.thumb.JPG.9a6c3d645caa4f7b3cc76b0b11e63b2a.JPG
Check out the shock though >.<
I think all up it took us 6-ish hours, we took our time I guess,
I picked up some V35 coupe rims?? 18x8 30p, my old wheels were 18x8 35p. I honestly don't think they will look that bad.
IMG_3331.thumb.JPG.910ca646bfe3eb10be0edcea654c8131.JPGIMG_3332.thumb.JPG.67d950547e25f1729fafc03af7599d7a.JPG
So that's about it... Subframe should go in the weekend after next.
They will look great on your car, I've got them on mineIMG_0369.JPG.622067ee0ab1416658792ec948a86111.JPG
Yeah they look pretty good on yours, I kinda want to get them powder coated but I'll see how I go lol.
Can't wait to put them on! [emoji2]
  • Like 1
Yep, I'm guessing because your car is white, a slightly darker colour would work well. I've never been a fan of black wheels, though - what's the point in having or buying nice new wheels if you can't see the detail in them.
  • Like 1
17 hours ago, JZMX32 said:
Swapped out my brakes this arvo
Front and rear 370z Akebonos
Endless rotors and pads
Braided lines
Whats the part number and where you got them from? Mainly the SS lines.
That looks like some decent bite there.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
