On 9/2/2019 at 3:00 PM, TMLP said:
Ok bottom end done full NITTO 3L grout filled & brace adapter for the sump & front diff. Waiting on the head ?
Head should be back from the machine shop tho week. Gone with big cams & valves, springs a shimless setup  plus  rear head drain & NITTO oil pump. Getting close.
  • Like 1
Pulled out both hubs to replace bearings only to find I need ball joints, cv boots & tie rod ends as well....
You would think Pedders would have picked up on this when they did their inspection and told me they crushed the ball joint when they put it in.
Never going there again.
Started extricating the stagea from the garage today.
planning to get it back on the road. just need to fit the cupboard full of parts i have for it.
5 hours ago, TukeH said:
Just one thing what I have been done 1month ago.
Went cardealer in southern Finland and chance my Stagea to this
Cool - more info and pics please!
Honda Odyssey absolute 2.4 k24a2 engine.
Only 200hp and FWR it is slow otherwise its much better driving than stagea and its more eco friendly 6-7l/100km
Future plans. air suspension and new rims
  • 1 month later...
Ok it’s gong in here are some pics as promised.
  • Thanks 1
  • 3 weeks later...
So on the Maatouks racing FaceBook page..
www.facebook.com/maatouksracing/
Shaun’s stagea came in for a MR 700 package packing a RB30/26, 6 boost manifold, garret gtx35/84rs, Turbosmart 50mm wastegate, ID2000cc injectors,custom cooler pipes and catch can all controlled through a Haltech plug and play ecu with all sensors and wideband for engine protection and peace of mind. Making just under 400kw @ 16psi at only 6000rpm on a running in tune.
6 hours ago, Duncan said:
great outcome from the engine these cars should have left the factory with :)
let us know how it goes once you lean on it a bit.
1000 k's on low boost the retune on E85 then I'll give it a bit & let you know how much I scared myself
40 minutes ago, KiwiRS4T said:
My C34 was pretty quick with 320awkw - yours should really shift with 388 and should be fun on the track with over 400!
I hope so, its going to be interesting to see how quick it is being so heavy after run in & the E85 & boost turned up ;)
On 11/30/2019 at 2:04 PM, RBW49N said:
Fitted this the other day so comfortable
What rails are you running with these?
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
