  • Replies 296
so what power is this monster making these days?
still the same, 700kw
argh... to much awesome in one thread its just not fair :)
lol =)
+11111111111111111111111111111111.
fn mental. lookn 4ward to c this in action again @ powercruise
can't wait to give the car a beating again =)
  • 4 weeks later...
I notice you went from a surge tank setup to the intank power-tune setup.
Not worried about / never had issues with fuel surge??
I havent had any issues with surging from the intank setup. There's no horrible fuel smell and no noisy pumps to buzz ur brains out at a set of lights.
yeh supose with that much power upgrading the stopping mechanisims of the car would be considered a good idea.
brakes look sexy
the standard brakes were ok, but since these came up for a reasonable price i couldnt turn it down.
How come you didn't bigger brakes? 700kw requires extra stoppage..
these are bigger brakes.... :)
This is one well equipped balls out GTR! Hopefully will see it again at the Motive GTR and drag battle this year.
Top stuff :thumbsup:
:) i'm hoping i'll be there too
