Haha, sounds good mate. Im back for 4 days in 2 weeks time. We should catchup and do it. Bring your car over on the 17th, stay the night and we can play with it on sunday the 18th?
17th rings a bell for some reason! Ill check with Carmen and let you know man :D
Being low in the 34 throws out the geometry of the suspension i think, the centre of gravity is out, bump steer issues, coilovers bottom out (they are only cheap stuff too).... There was quite a bit too it and i am probably giving all the wrong info BUT simple answer was to set the ride height about 8-10mm higher than it is now... Which will still look good and if it helps with handling then its win win!
I think it will reduce some scrubbing!
Lol be good to get some feedback from Richo actually ;)
Or come down to one of the SAU VIC Track events and just get him to drive at the track for a few laps :D
Lol with the track record I have had my car generally doesn't complete a few laps :blink:
Well hopefully that is a thing of the past haha
Haha you guys just wait for my 10 threads about what injectors to choose!
I would not be surprised one bit tbh :P
Just hurry the fark up, get some 1000s in there, get the jungle juice tune and get SKIDS :woot:
1000s won't fit in my stock rail haha
Learnt that from Scotty
Now I have to start a thread about fuel rails as well ;)
Screw Scotty :blink:
Haha well its been done 40000 times before so i am sure its not a new thing! You should try start a thread on that SAU forum type deal.............
How do I make my NA faster?
Why does my 3 inch exhaust sound bad on my NA.
Thinking of buying a skyline when I get off my P plates. Can you guys tell me how to get the loudest blowoff valve sound?
Nailed it! Now go fix your farking car Acting Senior Mani!
Hmmmmm 9.5's on the front.... They only come in a Matt Black and take 8-12 weeks to get done but i guess i can get them sprayed in Satin black to suit the others easy enough...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
