Haha, sounds good mate. Im back for 4 days in 2 weeks time. We should catchup and do it. Bring your car over on the 17th, stay the night and we can play with it on sunday the 18th?
17th rings a bell for some reason! Ill check with Carmen and let you know man :D
Being low in the 34 throws out the geometry of the suspension i think, the centre of gravity is out, bump steer issues, coilovers bottom out (they are only cheap stuff too).... There was quite a bit too it and i am probably giving all the wrong info BUT simple answer was to set the ride height about 8-10mm higher than it is now... Which will still look good and if it helps with handling then its win win!
I think it will reduce some scrubbing!
Lol be good to get some feedback from Richo actually ;)
Or come down to one of the SAU VIC Track events and just get him to drive at the track for a few laps :D
Lol with the track record I have had my car generally doesn't complete a few laps :blink:
Well hopefully that is a thing of the past haha
Haha you guys just wait for my 10 threads about what injectors to choose!
I would not be surprised one bit tbh :P
Just hurry the fark up, get some 1000s in there, get the jungle juice tune and get SKIDS :woot:
1000s won't fit in my stock rail haha
Learnt that from Scotty
Now I have to start a thread about fuel rails as well ;)
Screw Scotty :blink:
Haha well its been done 40000 times before so i am sure its not a new thing! You should try start a thread on that SAU forum type deal.............
How do I make my NA faster?
Why does my 3 inch exhaust sound bad on my NA.
Thinking of buying a skyline when I get off my P plates. Can you guys tell me how to get the loudest blowoff valve sound?
Nailed it! Now go fix your farking car Acting Senior Mani!
Hmmmmm 9.5's on the front.... They only come in a Matt Black and take 8-12 weeks to get done but i guess i can get them sprayed in Satin black to suit the others easy enough...
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
