Set around 8000rpm mate...
Not bad for an engines limit set 7000 RPM ;)
All jokes aside, it's going to be interesting to as how long it lasts at this power level. I bet, alot longer than what you'd think.
We will find out I guess... I have no intention of a built motor so if something happens to ole faithful then I'll be going stock again ;)
I need to learn to treat it a bit nicer I think :P
8500RPM on a hydraulic 25 head 3L.
This combo should explode according to the internet.
Sees the rev limit hard everytime I drive it :)
Internet knows all!!
Lol, love it...
Ill upload some new pics of a few jobs i have to do over the next week! No major changes at this stage, more general maintanance etc
Jumping back a bit in the thread (I'm still in Japan and it took me 20 minutes to catch up on this bloody thread :P)
I'm running 18 x 9.5 with +22 offset and I have 235/40 tyres up front. Have a look at my facebook pics if you want to see how that sits in the guards. All standard suspension arms, so you have the advantage of being able to make adjustments :)
Lol, ill jump on and have a look but i am pretty sure that is the sort of size ill settle for one day!
Yeah that is mine, just a crappy old pic! Ill have to send him a new one to use like i promised about a year ago :P
Been driving the car in sleeper mode, its so quiet with the gate plumbed in.... Will record some comparison sounds but for now this is all i have -
http://youtu.be/0rinWJ2M01g
Hahahaha!!! Awesome. :D
at least you can hear the tyres protesting when it's plumbed in.
Yeah they tend to whinge a LOT....
Actually on that note, with all these mods and all the research i have been doing i had to kick myself when i decided to check the farken tyre pressure and found they were 29psi in the front and 33psi in the rear.... Funny how we forget the simple things!
    • No. GKTech arms have spherical bearings in them. No bushes. You will not need bushes for those arms. The sphericals are a bit of a maintenance nightmare. I have replaced all of mine several times in the 5 or so years I've had them, and I have the arms out regularly to clean and lube the balls. Worth the pain on an R32, because the standard arm design is trash. If you need the camber adjustment, there are other options (than the GKTech ones), although I would still lean towards and prefer the GKTech ones, even with the maintenance load of the sphericals. The caster adjustment is also highly valuable, allowing for setting the car up to drive straight. There are a million options for these, including the GKTech ones. I've had Tein rods on mine for 20 years and the balls are much less trouble in that location. Never given me a moment's pain. All positives, no negatives. I consider them compulsory.
    • Lol yeah I ordered the clips mentioned and as far as the amayama diagrams go i think thats all I'll need. Fogured id ask, sometimes people's first hand experience doesnt always match up to diagrams haha, i guess I'll wing it and worse comes to worse I'll just deal with it as I go
    • Thanks for all that information I appreciate it. To answer your questions: - Yep that's what I mean. These guys are professional painters to so I must be missing something. It's a bit hard to explain. - With the primer landing on clearcoat, I make sure that the surrounding clearcoat is scuffed to 240 grit as my epoxy primer says that I only need to sand the area to 240 grit. - Yeah so similar to the first question, assuming that the paint landed on the unscuffed clearcoat because I've seen that happen. - Yep I want to prep the surface in that order. Only reason because epoxy primer will protect it from rust and I need that atm with this crappy Sydney weather. I think I was worried about time, if I try to put the filler down but screw it up somehow and I don't have time to sand it off and reapply it then need to put primer later that it might start to rust again so I wanted to apply the primer as quick as possible to not deal with rust.  - I just deleted some answers, I just realised after watching a video and what you said about looking at the data sheet, that I need to read the data sheet on the specific filler I'm using. It's possible now that I put epoxy primer first was a waste of time and need to go to bare metal lol
    • I did. I went to a suspension guy and he told me because I don't have adjustable camber arms it's the reason why my car veers towards the left if I take my hands off the wheel but if I drive my other every day car and take my hands off the steering wheel it goes completely straight. I think it's common with Skyline's. In order to fix the problem, I likely need gktech camber arms then nismo bushes since I have poly bushes atm, then a wheel alignment after that. With my car if I take my hands off the steering wheel on a really bumpy road before stopping at a light I have to hold my steering wheel somewhat tight otherwise my car will legit just go completely in the other direction quite quickly and I'll slam into something lol instead of stopping straight. I Believe this YouTuber had the same issue and fixed it with gktech arms. At timestmap 6:05 he talks about how the car doesn't veer anymore after installing these arms.
    • hello! does anyone have a schematic that shows how to test the blower motor resistor for the vac system? i believe the part# is 27761-15U00. I think the resistor is toast, but would like to be able to test it somehow before i embark on the journey to find a new one. cheers! 27761-15U00
