This is just a quick phone video from the roof at SMSP... You can hear the car coming around the back corners before you can see it haha... It was pretty slippery so was taking it pretty slow!
That looks heaps fun Matt. Car sounds so sick on gate.
Yeah once i can get it on a dry track and turn the boost up it will be some fun ;)
You looking after the black beast? Hope its going well...
Would like to see this thing boosted up in the track. Haha.
Beast is going good. Doing some 'light' reading on the Forced Performance section :) Lets see.
:woot: haha.... Good stuff!
Plenty of options around though, if you want to keep it stealth the HG turbos are getting good numbers or you can low mount a billet 3071 etc :D
Yes indeedy! HG is what Im leaning towards. The car will be a weekender in a few weeks time, so thats when the fun starts. I will contact you and pick your brains more about this.. :)
Anytime mate :) Just shoot me a PM if you need any info and ill do what i can to help!
This is a lap in the wet, trying to take it slow and feed the power but it was just too spin happy -
Love your idea of "feeding the power on". Just Stab that f**kin Loud Pedal! :laugh:
Good to see it's all working well and you're enjoying the Fruits.
:laugh: It got like that after a while.... I tried short shifting gears and taking it easy but it was just too slippery so i just drove it Powercruise style after a few laps :P
Its a good feeling to have it running properly that is for sure.... You think a return to SAU Nats 2 years later with some success? ;)
Hahaha could gear it from the pit while you were going through 5 and 6
Lol it was only on gate pressure so not as loud as normal! :P
Car sounds awesome Matt, are you going to texi?
Thanks man! Might be coming down for the day but the car wont be... Ill be saving it for some bigger events :yes:
Hopefully I can join you for SAU Nats this year. Car is coming along strong Mat!
Hope so man! How is the new beast?
Here is some more of session 2... Also shows 5th gear is starting to suffer, i keep getting a gearbox full of neutrals when trying to shift hard :/
Nice vid. My 5th gear has been grinding in ever since I got it if I change into it at anything over 80km/h :(
Still hasn't passed compliance.
It's been at their workshop for 2 months now due to paper work delays.
Hopefully it will be ready this week.
Damn :( I want pics and stuff once its done!
I had a chat to my Diff/Gearbox guy today and he said it needs a freshen up! 4th is tricky at times too! Apparently the synchro on 5th is really small and normally doesn't have issues as its gently shifted on highway speeds, but once you start tracking and smashing it into gear i guess it will start to hurt :( Also, need to extend by diff and gearbox breathers in the near future!
Good to know haha. I never do track days that require 5th so hasn't really bothered me as yet lol. The guy that owned my car before me did a lot of highway driving from Bathurst to Sydney so I'm just guessing he didn't change back when he should have and put too much load on the gear through the moutains or something.
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
