Bad thing with the jap exhausts is they're all quoted at the largest point - what they fail to mention is that there's usually a reducer before the muffler. Thats why the local stuff is better - even if it is more costly than the mass produced jap stuff
  • Replies 136
Posted Images
i have 3.5" from dump back (4"dump) with two big mufflers in it, meets NSW noise requirements and for the most part is custom. most of the jap exhausts start at 3" just after the cat then expand from there and or have reducers before the mufflers (if you want it to not sound like a straight pipe you need lots of muffler a cannon on the back is going to do next to nothing)
i spent a long time looking around for off the shelf options aside from racepace you are pretty much left with giving the car to an exhaust shop (or have a friend that can fabricate it for you) and getting a system custom made with as much or as little muffling as you want in the pipe size you want.
Problem is giving it to an exhaust shop - it's a gamble.
You ask for a "90dB" exhaust, and they will not take on the job because most have no idea, and cannot give you an indicator of how lound it will be.
What is your exhaust dB level Titan?
I'm assuming it was measured @ 4900 rather than 5100 like a RB26? (the 200rpm does make a difference). :)
That said I really cannot see a 4", straight through exhaust being legal - ever. It's just too large.
So best option is to get is as close to legal as possible, and therefore less attention.
I'm still looking into options, another option has popped up this week on top of the 2 others... So the GB will go at some point, just have to get prototypes made and try a few different mufflers (which will take a while given it costs $$$).
I'm still looking into options, another option has popped up this week on top of the 2 others... So the GB will go at some point, just have to get prototypes made and try a few different mufflers (which will take a while given it costs $).
mine pulls off 89-90db. its borderline but its a pass, the VIC system where it has to be below 91 from idle to test revs and back it wouldnt pass. there is just no way to get a large pipe legal at low revs there isnt enough flow for the mufflers to work properly even my massive mufflers only manage 92-93db at idle.
on the back its a 18"x11"x8" offset -> centre 3.5" straight through and a 10"x8"x5" centre > offset 3.5" straight through in the middle.
the more gas you pump through it the quieter the system gets, there is more road/wind/engine noise cruising around at 3000rpm than there is exhaust which is fine by me.
when i was looking around i was asking about custom made to order muffler sizes it adds a bit to the cost as the mufflers are $250-400 each depending on size and material (stainless vs mild steel) and then you still have pipe + flange + labour costs. the way i look at it the bigger the muffler you can stuff into the masses of space on the back the more ground clearance you can have from the middle one. i really wouldnt be going much more than 5" high in the middle as thats pushing it though.
89db? Or 92-93dB?
You've listed two different levels and the difference between 89 and 93 is not linear :)
And just to be clear - you were measuring @ Idle - 1100rpm? Not the "EPA" test of 4900rpm?
What distance was the measure taking? 1m? 2m?
Gotta get specific if people are gonna understand what you mean :)
You CAN get a 3.5" borderline legal. We managed to get mine down to 92dB @ 5100rpm with a lot of farting around. 1dB off which was a fair effort and that was without any extra baffles etc.
89db? Or 92-93dB?
92-93 @ idle (~900)
89-90 @ test revs (~4000) RB25/30 engine so the RTA only asked for test revs for an RB30
standard 45 degree 0.5m nsw rules
i do not have any restrictor plates or other such temporary noise reducers in the system it was taken in exactly how its driven every day
anyone have evidence of a 3.5" system being restrictive on a gtr? and at what power level?
only one i know of was the guy in SA with the 33gtr that put twin 3" side pipes on and gained 80kw.
any other examples? almost giving up on the hunt for a titanium 4".
Edited by tk80
a mate got a 90 mm system in Ti made for his s15 and it wasnt that much. About $2,000 I think. The guy came out, measured and welded it in a day. I could get the number and more details if you like?
Don't amuse do some awsome Ti exhausts? Not sure if they are quite 4 inch though.
I find it amazing how hard it is to find a 4inch off the shelf item when everyone says yu nees one if u plan on making over 400kw.... i mean heres heaps of people making 400kw atm!! Whats everyone using? Shorly not everyone has had a custom 4inch made
Most people @ 400rwkw don't care about noise.
So ye, most of the time it will be custom with just a rear muffler really. In the grand scheme cost isn't much more over whats already spent.
It's a QUIET 4" exhaust, that's the challenge
This thred is splitting into two with exhausts and turbochargers but exhausts are an interesting topic so maybe I can ad a bit .
I've been researching exhaust stuff for my Evo 6 because I want acceptable road car performance and it has to be QUIET .
Now back to Nissan I was looking at an early Z32 300ZX recently and I was remembering how they had two cats or at least one with two bores through it . By any chance can you splice two cats in before the engine pipes merg into one because if you can each cat is only catering to three cylinders exhausting half as often as the one cat would after the merge . Even if so could have legality issues because I'm told the cat is suppose to be in the std position under the car . Being closer to the turbos they should heat up a little sooner but I guess it all comes back to your and the states interpretations of the laws . These 6.2L Chevs seem to deliver the numbers so they must have something reasonable cat wise - x 2 .
Turbos , my gut feeling is that GTRS GT2871Rs by two would not be ideal things , better suited to a single turbo app where a slight exhaust gas restriction is less of an issue . I don't know if anyones tried the 48 compressor trim version of the GT2871R , GTRSs are the 52 trim version .
One thing I don't think anyones thought of is a version of the GT2860R like a "2530" but with 60 trim compressors . This is what the four cylinder version of the GTSS has and its possible that it would spool somewhere between RB26 GTSSs and RB26 "2530s" while not being that far behind the 2530s .
Personally I think big power in a RB2568cc engine is a useless on the street . You can't use high rev power around the suburbs and if you have to go back more than one gear at highway speeds what was the point ? IMO only two things can pull the bottom end power up on an RB26 without compromising top end power . First is VCT and second is more capacity . There is no easy way particularly as centrifugal turbochargers are a compromise and at best they can span 2/3 of the engines usable rev range . Your call as to which suits you better ie the first 2/3 or the second 2/3 . Other means of airflow control ie variable valve timing DO make a difference but obviously this is not what Nissan was concerned about . They chose to fit GT2556R turbos to late GTRs and even these don't shove you in the back at "normal" revs/speeds .
Anyway your calls , 2530 or GTSS if it was me and twin cats before the merge if at all possible .
A .
i'm at 453awkw on a 3.5" system. will i really get a miracle extra bit of power by upgrading to 4"???
You are E85 ye?
That does change things a little with how much you can get etc. Same as race fuel does.
Easiest way to tell, drop it from the front pipes.
Myself and Heslo are getting 4' titanium exhausts done from am performance here in sa in the coming weeks. Just waiting on the material. He has done some before but currently not enough stock
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
