Are you planning on doing any work on the auto box to strengthen it up a bit before putting the turbo on, or just gonna see what happens?
Nice car too, it was looking really good on the 15th Anniversary cruise.
Thanks Mate, good efforts on making it from Bathusrt too!
My plans for the box is basically the transgo kit, and a transcooler with Thermostat. On the Transgo site, it says that the kit for this box is designed with turbo/super charging in mind. So with those two things in the box, I'm hoping it will cope. From what I have read, its mostly about keeping the temp down, as to not fry the box. Generally I don't drive it like I stole it, so if it survives the tune (which I will tell them about the box, and to be mindful of it) I'm pretty sure it'll go fine on the road.
Will that have any effect apart from speeding up the shifts? I was thinking more in terms of protecting the gearbox from any problems caused by the increased power levels, if that is even going to be an issue.
I thought that's what shif kits do??? :blink: to prevent "flaring and destructive gear changes" as per Jetwreck's words...
fkn LOL @ Dale.
Also LOL with Dale :)
Very interested to see the sump mod Alex
Is that cause you might be pinching one...? Sump has been cut to clear all various extra bits and pieces. It's going to be welded up monday. I'll get photos when done.
Lol Dale- its a build thread, not just a look at my POOOOWWWWWWWWERRRRRRRRRRR thread thumbsup.gif
Plus, someone said we have to fix a big black pile of backfarting parts first before getting carried away...tongue.gif
I'll get some photos of the kit up first. That'll shit Dale some more...
Take your time & do it right; I'll stop filling your thread with junk now.
Watching with interest as this develops; it's going to be a very interesting package, with performance to match the looks.thumbsup.gif
Carry on.
good to see my hks turbo kit is going to good use. funny thing is now i want a m35.....lol
Do it, Dave!
BTW, is that John's new engine I've been hearing the past few nights over here? Fck me, it's loud, but it also sounds good!
Well, I got the sump back on friday arvo. Got modified to clear the front diff, and the stock oil cooler piping. This is what it ended up looking like.6275907256_845b266094.jpg
The hole on the rhs is for the oil return. When I got it the wings were the same size on both sides. The screen door in the top of the sump seems to act like a baffle.
Edited by PN-Mad
1319442563[/url]' post='6077090']
Custom modded HKS sump, noice. When are the goodies going on?
Well, now I have everything I want. So, we want to sort out Craig's car before another ends up in bits all over the place. Hopefully within the next month or so. Wish you were in Sydney, I'd be getting you to make up a exhaust.tongue.gif
1319442918[/url]' post='6077105']
Nice Alex. Very nicely done.
Lose about 200ml of oil I guess? (not that it will matter)
yeah, probably lost a bees dick worth of oil. Not much to worry about.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
