Are you planning on doing any work on the auto box to strengthen it up a bit before putting the turbo on, or just gonna see what happens?
Nice car too, it was looking really good on the 15th Anniversary cruise.
Thanks Mate, good efforts on making it from Bathusrt too!
My plans for the box is basically the transgo kit, and a transcooler with Thermostat. On the Transgo site, it says that the kit for this box is designed with turbo/super charging in mind. So with those two things in the box, I'm hoping it will cope. From what I have read, its mostly about keeping the temp down, as to not fry the box. Generally I don't drive it like I stole it, so if it survives the tune (which I will tell them about the box, and to be mindful of it) I'm pretty sure it'll go fine on the road.
Will that have any effect apart from speeding up the shifts? I was thinking more in terms of protecting the gearbox from any problems caused by the increased power levels, if that is even going to be an issue.
I thought that's what shif kits do??? :blink: to prevent "flaring and destructive gear changes" as per Jetwreck's words...
fkn LOL @ Dale.
Also LOL with Dale :)
Very interested to see the sump mod Alex
Is that cause you might be pinching one...? Sump has been cut to clear all various extra bits and pieces. It's going to be welded up monday. I'll get photos when done.
Lol Dale- its a build thread, not just a look at my POOOOWWWWWWWWERRRRRRRRRRR thread thumbsup.gif
Plus, someone said we have to fix a big black pile of backfarting parts first before getting carried away...tongue.gif
I'll get some photos of the kit up first. That'll shit Dale some more...
Take your time & do it right; I'll stop filling your thread with junk now.
Watching with interest as this develops; it's going to be a very interesting package, with performance to match the looks.thumbsup.gif
Carry on.
good to see my hks turbo kit is going to good use. funny thing is now i want a m35.....lol
Do it, Dave!
BTW, is that John's new engine I've been hearing the past few nights over here? Fck me, it's loud, but it also sounds good!
Well, I got the sump back on friday arvo. Got modified to clear the front diff, and the stock oil cooler piping. This is what it ended up looking like.6275907256_845b266094.jpg
The hole on the rhs is for the oil return. When I got it the wings were the same size on both sides. The screen door in the top of the sump seems to act like a baffle.
Edited by PN-Mad
1319442563[/url]' post='6077090']
Custom modded HKS sump, noice. When are the goodies going on?
Well, now I have everything I want. So, we want to sort out Craig's car before another ends up in bits all over the place. Hopefully within the next month or so. Wish you were in Sydney, I'd be getting you to make up a exhaust.tongue.gif
1319442918[/url]' post='6077105']
Nice Alex. Very nicely done.
Lose about 200ml of oil I guess? (not that it will matter)
yeah, probably lost a bees dick worth of oil. Not much to worry about.
    • What Duncan said sounds right. Also, it looks like they only have the driver's mat. Not the rest. Because looking at the diagram: KG4911 is just the mat for the driver. KG4900 is the full set if I'm not mistaken and discontinued.   But, it looks like they may still have the full set for the manual S2. Might be worth checking for the other models as well as they seem slightly different. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/misc/G49 Man, I'm tempted.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
