Are you planning on doing any work on the auto box to strengthen it up a bit before putting the turbo on, or just gonna see what happens?
Nice car too, it was looking really good on the 15th Anniversary cruise.
Thanks Mate, good efforts on making it from Bathusrt too!
My plans for the box is basically the transgo kit, and a transcooler with Thermostat. On the Transgo site, it says that the kit for this box is designed with turbo/super charging in mind. So with those two things in the box, I'm hoping it will cope. From what I have read, its mostly about keeping the temp down, as to not fry the box. Generally I don't drive it like I stole it, so if it survives the tune (which I will tell them about the box, and to be mindful of it) I'm pretty sure it'll go fine on the road.
Will that have any effect apart from speeding up the shifts? I was thinking more in terms of protecting the gearbox from any problems caused by the increased power levels, if that is even going to be an issue.
I thought that's what shif kits do??? :blink: to prevent "flaring and destructive gear changes" as per Jetwreck's words...
fkn LOL @ Dale.
Also LOL with Dale :)
Very interested to see the sump mod Alex
Is that cause you might be pinching one...? Sump has been cut to clear all various extra bits and pieces. It's going to be welded up monday. I'll get photos when done.
Lol Dale- its a build thread, not just a look at my POOOOWWWWWWWWERRRRRRRRRRR thread thumbsup.gif
Plus, someone said we have to fix a big black pile of backfarting parts first before getting carried away...tongue.gif
I'll get some photos of the kit up first. That'll shit Dale some more...
Take your time & do it right; I'll stop filling your thread with junk now.
Watching with interest as this develops; it's going to be a very interesting package, with performance to match the looks.thumbsup.gif
Carry on.
good to see my hks turbo kit is going to good use. funny thing is now i want a m35.....lol
Do it, Dave!
BTW, is that John's new engine I've been hearing the past few nights over here? Fck me, it's loud, but it also sounds good!
Well, I got the sump back on friday arvo. Got modified to clear the front diff, and the stock oil cooler piping. This is what it ended up looking like.6275907256_845b266094.jpg
The hole on the rhs is for the oil return. When I got it the wings were the same size on both sides. The screen door in the top of the sump seems to act like a baffle.
Edited by PN-Mad
1319442563[/url]' post='6077090']
Custom modded HKS sump, noice. When are the goodies going on?
Well, now I have everything I want. So, we want to sort out Craig's car before another ends up in bits all over the place. Hopefully within the next month or so. Wish you were in Sydney, I'd be getting you to make up a exhaust.tongue.gif
1319442918[/url]' post='6077105']
Nice Alex. Very nicely done.
Lose about 200ml of oil I guess? (not that it will matter)
yeah, probably lost a bees dick worth of oil. Not much to worry about.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
