Well, I drilled holes in one of the manifolds last night; so it may never run again...
Hope everything went smoothly today, and that Craig didn't have a protein shake for brekky; too much powaaaahhhh!
Finished for today. We're both stuffed.Manifolds on, crossover pipe , heat shield on. Turbo on and tight. Intake on. O2 sensors on and heat proofing in lots of places. Oil and water feeds to turbo done, have to do returns. Need to fabricate turbo outlet piping, and exhaust from where the gate goes in needs to be extended. I'll post some pics tomorrow when I'm not exhausted!
Big thanks to Craig for putting in the lions share of work, and Dale for fixing up a boo boo last night, even at a BBQ! Both legends, and can't thank you guys enough. cheers.gif
On a note, never put your hand up to change v35/350z headers, not in a million years!
When attempting difficult jobs, its important to be precise and organised....
Trial fit
Is it getting heavy yet? I'll just take moar pics....
The Manifold- couldn't fit a fart up there its so tight...
Ready for a manifold on the drivers side- Except this one has a bit of Daleo Magic in it!
Craigs fav. work-zone: Turbo, gate, washers and beercheers.gif
Looking a bit bare...
What turbo officer...?
That ends it for now.
you didnt drop the engine to install the manifolds???
nup......I have cuts and abrasions to prove it!
IMO theres about 5 hours of work left.....tops!
not including the 2 bits of custom stuff that needs doing
Edited by Jetwreck
lolz.........we not only have 1 hoist.....we have 2 at Stagea Garage! nyaanyaa.gif
Bah! Weak!!
Or perhaps I am a touch jealous of not having to lie under the car holding the exhaust in one hand whilst doing up nuts with the other....
Scott removes NM35 turbo's without a hoist or removing the engine quite often.
You won't be able to remove the turbo and manifold as one. The turbo will need to come out, then the manifold
Edited by iamhe77
Does that mean then you could remover the turbo from an NM35 without engine out? Is it possible if its turbo and manifold in one?
yes it does....every turbo I have done has been with the motor in the car. However I did my turbo while the motor was out and it was so much easier.......I am actually going to trial just removing the Crossmember this weekend coming on a NM35......his got the same turbo as me so it's a little more fiddly so I probably wont get it done is 2 hours like Scott can apparently do!....I estimate about 10 hours!
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
