It was out of SAS's league, what makes you think they can do it? Even the Japanese have only hacked the fuel and timing maps afaik.
I have gone down a different route anyway, not looking for an ecu hack now as for years I have been let down. The HKS will be going in when I get back from Qld.
I never said they "could" do it but seeing as they are both electronic engineers in software and hardware and developed Nistune, I thought I'd ask if they are planning on having a look to make it easier for us all.
Engine bay looking good PN-Mad
Edited by slippylotion
Intercooler is crooked.
(Hey! So I'm a little OCD...)
Must've been Craig's fault :P
It is crooked- but as you know, if you want it straight, you'd have to chop out more of the FRP bar- thus reducing strength. I'm happy for it to be a bit crooked, cause I'll never see it behind the front bar!
Nah, no extra chopping... just pick a lower hole for the bracket (near bonnet clip) to be bolted into.
Then the other two wouldn't fit....anyway- not OCD with things I can't see!
How long did your mate drive it around without a tune? Did you do anything to help the engine?
I'm planing to remove 2 degrees static timing (the limit of what I can do without the flash software) and maybe get the bigger fuel pump in there to give the injectors a bit more room up top. Just in case you know.
He is still driving it around without a tune... although the BCM is letting go so he has intermittent wipers when it is dry and none when it rains (lol!) among other electrical eccentricities.
Have one coming in so should be back to normal in less than 2 weeks, but has had no mechanical issue at all.
Only other thing that was done was a Race Radiators custom radiator installed at the same time.
Update: Fabrication of the Intercooler piping, and exhaust are COMPLETED banana.gif
Happy with the result - the turbo outlet to pipe is amazing- I'll get some pics up in the coming days. I hope to hear its voice tomorrow, with the remainder of things being assembled/plumbed/filled/tightened etc.
The HKS GT-II External Wastegate controls the boost. It has a 0.35BAR/ 5psi (supposedly) spring inside. This functions as the boost control. It will be tuned at that level, and once everything is sorted and any problems figured out, then I propose using a manual boost tee of some form to run no more than 0.5BAR. That is considered the safe max for the stock block, and nets good power, however I have see stock blocks with 10 or 12 psi holding up on the US sites.
Edited by PN-Mad
Depends a lot on where you measure the pressure I think.
I have a feeling it will end up at about that level too, but we'll just have to see.
Meh, 7psi?
Get some e85 in the tank and dont put too much timing in, you should be able to push it to 1 bar no problem. :banana:
Where are the pics?
Meh, 7psi?
15psi on a stock VQ35 bottom end?
Think it'll take more than fancy fuel to keep it alive, but feel free to put your spare VQ35de in your car and let us know hit it goes Buddy. :P
Where are the pics?
Im sure a lot of the feedback on rod strength from the US is just bad tuning. Too much timing and det is what kills rods not boost, E85 will help with both issues.
I guess my motor is just super strong right? Even though the rods look very similar in size? The amount of times I have heard "dont run more than 20psi" or "dont use a p1ggyback computer" now it just makes me smile. :whistling:
x2 bad tuning kills em.
If you get det, in-cylinder pressures might go from 1000psi to 2000-2500psi suddenly, if this happens BTDC then Mr Rod has huge stresses on it.
As long as you make sure that peak cylinder pressures are reached 8-20 deg ATDC you make best power, so if the tuner doesn't get too cute with advancing things beyond the ability of the fuel to produce a smooth flame front then there is no reason you can't stuff more boost in.
QFT.
The main benefit of ethanol being it burns slower than 98, right through the crank's downward travel. Thats where the extra torque comes from.
I hope you have a good tuna picked out... :whistling:
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
