So, had the lil nugget on the Dyno up at DVS JEZ tuning today to check the tune out, and make sure everything was nice and safe. Also to see what powerz we make. So quick recap - S14 SR20det, GTX3071 6Boost mani, tial 44mm ext gate. 98 pump gas
dyno vid:
http://www.flickr.com/photos/67036277@N07/8529131921/
8529149563_fa10295415_c.jpg[/url]
IAT? Come on mate, this isn't powertunez!
At his power level, there is very little point pushing further. Drag car - yes, street car - yes, "powercruise" and the like - yes
Track car - no.
We have to sort the traction out first before adding power. Fast cars need handling more than they need more power. And its plenty enough for me at the moment.
Good thing is, the GTX is just getting into its stride at 18psi. 26/28 pound is a real possibility. So its in reserve. E85- I do like the idea, but its extra hassle and convince of pump is nice.
The good news is that Jez's dyno reads pretty much exactly the same as Unigroup dyno. So you can be confident there are no shenanigans with Jez tuning and he will be careful with SR20's due to the noise they make. There are no prizes for making them rattle.
  • 4 weeks later...
180sx update:
So I found this magical store called GKTech that sell all kinds of goodies cheap :) Its a pleasure us stagea owners don't really get, having access to plentiful supply of reasonably priced decent quality parts.
Anyway, ordered their caliper brackets, a upgraded engine fan, and some adjustable rear toe arms to replaced the one that is bent.
I went about replacing the very tired brakes with these new items. The pads that were in it were shot. They were once Bendix ultimates (0-550 degrees), but they had been turned into powder. I'll upload a pic later. So bendix ultimates as a track pad - NO!
I phoned up GSL rallysport and put an order in for A1RM (0-780 degrees)pads all round, and a bottle of TRW GP600 fluid. As usual, great service by these guys, and it was on my doorstep in less than 24hrs.
New billet caliper extenders bolted up, 2 piece rotors on, and pads in, it was time for the Mrs to be called up to do some bleeding. Bled the Clutch too for good measure. Took them for a quick drive to bed in, and the results are amazing. Great pedal feel, and good stopping without having to heave on the pedal to get results. Time will tell if they hold up on the circuit.
Still have to install the toe arms and rad fan, and get it aligned. I'd really like to find out some good suspension alignment specs from some of these track guys and see what I have to get to make it all work.
I may have a lead on an oil cooler, so I will chat about that later, and I'll chuck up some photos for effect tomorrow :)
Well, bit of an update. I forgot the other day to show you what I picked up!
As part of my work we get a "health lifestyle" reimbursement. I shot an email off, and after receiving confirmation it was NEW HELMET TIME!!! Daleo recommended a trip out to MCA at Auburn. A very helpful lady out there steered me through the process, and I settled on the Bell RS-1. What I love about it is its really well ventilated for sweaty dream boats like me, and although it is full face, it has heaps of room round the mouth so that it doesn't feel as closed in. I also got some Alpinestars Gloves, which while they are pricey, are super comfortable and nice to be in.
Yesterday I took a trip down to Wollongong, to pick up this little kit. I'm not going to have it fitted in time for the track, but will give me something to do after if it doesn't break something else. So its a brand new GKTech adaptor place- I got warned off the sammich style because they break off the thread regularly on SR20s. Not only that, but the way they have to sit means the lines are really crimped up, so this unit is stacks betterer. Along with a oil filter re-locator, and a 19 row core.
The only thing is I also have this brand new ARC core. I think I will use the one in the kit I bought, because the ARC one is just so pretty. I'd hate to bash it up..... maybe it'll go on later.
I also had the adjustable rear toe arms put in, cause I don't have a rattle gun, I couldn't for the life of me undo the bolts! So I just gave it to a place that was going to do the alignment.
So the alignment specs are:
Front:
-2mm toe in
-2.2 degrees camber (max I could get front the strut tops)
6.5 degrees castor (as much as he said it could get)
Rear:
-2 degrees camber
-2 toe in
So we'll see how it goes Tuesday at Wakefield!
Nice helmet, but how do you see out with all that writing?
Nice one Alex!
The new range of Bell Helmets have only just been released in Australia, and the specs looks really good.
The prices definitely won't stay low forever.
You'll look the part; so nothing else really matters!
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
