I was going to get 550's in and hop around with that for a while untill I get the power fc in and tuned. Now im just thinking I'll get the 750's slap em in got new pod filters waiting to go in, get a adjustable FPR and I'll put my power fc in and change oils untill I can get it booked in for a tune and most likely strap it to the back or a trailer and tow it down.i dears??
stock ecu will not like 550cc injectors. You will need a tune with any larger injectors put in. I asked Trent for a tune off another car with larger injectors so I could have the car driveable to his workshop. You could always do something like that, but dont expect great fuel economy or for it to be safe (if its leaning out)
You'll be fuckin fat bitches in no time!
KFC can probably use shit chicken cause the fried coatings cover it up...do they actually have anything that isn't fried like Nando's?
So what about them house prices ey?
I've been monitoring the market closely and reading all from all points of views and by the looks of all things, including the international markets namely the EU zone and China's slowing market and its dropping house prices... things are about to get nasty.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
