haha this needs one of those meme's seen a couple pages back. Havent seen one for Engineer yet :P
I worked at a supermarket between highschool/uni break, pissed off after end of first semester to a better job. Shit pay & long hours.
Managers in any business need to learn to show respect to people and to do this is to unlock the maximum potential of the employee.
By paying people to only do one task is implying that you are only capable of doing one thing and is a sign of disrespect. No wonder the same attitude is displayed back to the company...
my tip; look for a casual job which utilizes your capability you will be happier off.
Good points there Pat!
Very true too.
Was just implying Alvin should do something in his field of study, hence Engineering.
Hey Bluejeans!
Saw your car and thought I'd buy 5 of them!
Damn, I miss mine :(
When I get back, imma trying to get another one, hopefully 300+ kw.
i've yet to graduate..
but i'm considering starting up a hotpot restaurant..
I see, let me know about the hotpot restaurant.
I am looking into expansion / investments... More so scoping out opportunities.
yeah, that's one of the cheapest startups.
and with so many azns. i'm sick of the hotpot places run by the prcs... they're crap.
Yeah, what's with that? Way to stuff with the OCDs!
Gixxers are nice.. I find the thousands handle far nicer than the 600/750 though.. Both are hawt. New 600/750 not so much. New thousand yes please.
Something about the new gixxers just doesn't look right....Front headlight too big or something...
My mate has a k7 or k8 600...looks the goods. Think that's what I'll be getting but a 750
Agreed. Actually, late model gixxers on the whole I'm not a fan of the headlights. They just look too busy and dorky, doesn't seem to fit with the rest of the bike's lines.
Mates R32 gtst got broken into last night, little rats stole some change, his paintball gear, pod filter and boost gauge. Why would you break into someones car to only make off with a) shit you cant use and b) stuff only worth like $20
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
