$10,400 cover on my car with just car insur. Unfortunately it's $2000 excess lawl. $1,400pa
Whoa $1,400p.a on a $10,400 car.
Insured for about $18K and pay about $700 for full comp over here with just cars. Your area that bad lol?
Pay $300 bucks for skyline 10k if it's stolen.. Third party of course
But really insurance on an import is almost pointless especially if it's modified they could find 100 reasons not to pay out on half our cars
Yeah I got 3rd party just wanted to check how much full is. Just car has standard excess + vehicle excess + age excess. totals to $1950 excess
I'm sure I would get cheaper if I called up and used my 3rd party history with them. Was just a random online quote.
Give it a shot tony, would be interesting to see if they quote the same.
Another advantage to the third party is the significantly lower excess than you were quoted with full comp. If you have some sort of pissy love tap that hardly damages your vehicle, but leaves you with a grand of damage to the other vehicle, it won't be worth claiming under full comp, but might be under third party.
Telemarketer: Hello can I speak to the business owner
Me: Speaking...
Telemarketer: Hello sir I am from Telstra, the reason I am calling is because I want to save you money on your monthly phone account
Me: I don't have a phone
Telemarketer: *silence*
Telemarketer: How am I speaking with you right now?
Me: GET OUT OF MY HEAD
No that's because you sent me a message while I was watching Falling Down, and no one interupts me while I'm watching that. Then I forgot about it. I'm away this weekend, if you can wait til Friday week we'll head to CQ?
Aren't u like 30 already? ;)
Car booked in for turbo install...could not be assed attempting it and dealing with broken manifold studs at the same time. Here comes the sun, little darlin'
For sure, it's been too long. Good chance to build some more rapport in the meantime
Who you gettin to do turbo install? Rob?
OTR...they've done a couple of HG turbos and work on Tao's car so should be familiar with fittings etc.
Then I'll drive it to RevZone for some tuning.
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
