No idea, I went on there to post in some thread ,... couldnt do it checked some shit apparently I've been banned from posting ... hahahaha I usually get in there and make threads about drifting lavo factorys n stuff for lulz then they shut down the threads.
I have a dilemma, that is what way to go to London via.
There's some of the routes enroute.
Beijing
Beijing & shanghai
Dubai
Abu Dhabi
Bangkok & Cairo
Kuala lumpar & Bangkok
Hong kong
And few places in middle east region including Jordan, Qatar.
If go thru china, the flight will be the longest but it's whole heap cheaper.
Hong Kong is pretty expensive - only available if using Qantas, Cathay Pacfic.
I'm leaning towards middle east route unless I want to see if there's counterfeit goods on duty free in china.
So far dad and both my brothers tried to talk me into staying Dubai for couple of nights...
/tl:dr post.
ive been hong kong / beijing / bangkok
out of those 3 id say go hong kong by far.. beijing is 13 hours if i remember right, bangkok airport is like a military controlled complex, they have their military people with machine guns on them at the airport...
but on the other hand - dubai and abu dhabi could be funs! :D
Thing is, I'm not looking to spend $ on stop overs cos I'd rather waste it in UK/Europe as I'll probably spend up to 2 years there - have work visa in the UK.
Been to Bangkok airport something like 7-8 times over the past 6 years
Honestly cannot remember any Military presence on any occasion.
Beijing
Beijing & shanghai
Dubai
Abu Dhabi
Bangkok & Cairo
Hong kong
/tl:dr post.
Counterfeit stuff cheaper in HK or bangkok
add in if you want to leave airport in China there is a visa so there more money to spend.
accom in Dubai and Abu Dhabi can be very expensive for safe good accom, (and you will have all your stuff with you)
that said like all things with airlines you get what you pay for.
and remember you will be stuck in your seat for upwards of 24 hours.
so things like:
every seat in economy on Cathay has it's own power socket
Qantas 380 has a (non alcoholic) bar where you can get drinks and snacks any time on the flight
so is the important thing
cost
stopover
comfort on flight
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
