All cars are like that not sure why but never seen a car that doesn't have one wheel in more than the other
Ive heard its due to the diff being slightly offcentre or the subframe it self being slightly offcentre.
Car manufacturers never expected owners to be running wheels so close to the guards that you can tell the difference haha
I don't understand how any of this makes sence, the allignment tools have Indipendang levels in them. If its out, it's out.. Unless there is some auto correction when you put the specific car in..
But birds what you said doesn't make sence because how are they going to compensate for fat dream boats like me?
I think what Alex and I are talking about is the offset of the wheels to guards. Majority of the time, one wheel will sit out more than the other side. The camber setting would probably be the same on both sides hence why one side would look slightly different in reference to the guard/body etc
i dont know, its friday.
Well when I got my car alligned at Centreline...and mind you I have adjustable poly bushes on just about the whole frikken car...they corner weighted it and alligned it so that with an ~80kg driver, there is a near 50/50 side to side weight distribution and the camber sits about the same on both sides. Sucks when you have a passenger and can tell the difference though...
This and what birds said I think the thing is off centre so even though the camber is the same the actual wheel position is out a little bit on one side even although the camber settings are the same.
Shitted me with the 33, but no two guards are rolled perfectly the same either which probably doesn't help
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
    • Item 10: Tech Edge wideband sensor interface and display. You’ll need to buy a new sensor. $150. Item 11: part of a Willians 5 point harness. $40 Item 12: OS88 gear display. No need for it now, my PPG sequential came with one. $30
    • I took it out, even though I knew I probably don't know what I'm doing other than looking for power signal lol. Lesson learned here I guess, even if it looks normal, worth checking as it only takes a few seconds anyhow. And maybe disconnect the battery, even though really shouldn't have to.
