What I did all day
Is that your engine or a spare?
What are you plans?
Not sure how discounts and what not are going to work as such, I've got a big 8 weeks coming up to get it all sorted (it's a bare shell at the moment).
Rest assured though any SAU guys that come down and bring friends etc, I'll be sure you look after everyone - and we'll have the best steaks in the east :D
Get the restaurant to become a SAU VIC supporter broooo. Free advertising and just give a small discount to members
Congrats on the venture, wish you the best of luck with it. Also wish I had the guts to do something like this. That being said, I've worked for myself before and want no part in it anymore lol...jaded.
I used to organise dinners for my friends, so I'll endeavor to make it down there given I'm just around the corner.
Curiously, does the franchise permit you to have your own menu of steaks? Would love to see another place offer stone grill in the east. Easily Paesano's biggest (if not, only) drawcard.
What did you buy?
I've got 235 Federals on a 9.5" rim, they are pretty wide for a 235 so should give you a reasonable idea.
Pics in r33 thread
Just some Varrstoens, cheap and quick to get before SnS :P plus I really like the look of them.
Probably get some "real" wheels in a year or something.
Are varrstoens imaginary? Lol
Lol, you know what I mean thought I'd just address it before the haters.
Basically they will poke out 25mm more than standard wheels, 'sortaflush' fitment but practical to get some big rubber inside when I want to.
Nah man has entire got blokes out there? desent job?
sweet do you make awesome statues in stuff? haha
Can have anything made at a price, all made in China nowadays though.... Couple good ones have been a Ferrari, Motorbike and some of the angel carvings come out awesome (lots of details in wings, so they look pretty cool)
Do you do well done?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
