gay..
rockford subs and amps.
warmer sound.
stronger more stable bass.
Not according to the car audiophiles/workshops & various awards
W6 line of JL car subwoofers are renowned for their SQ and pretty sure they have won many awards with that line of subwoofer.
This was 2-3 years ago but I'm sure the same still applies
Just sayin
Just sayin
I was referring to the alpine range.. Although I'm not really a fan of JL audio either..
Especially the type r splits and co ax.. Never liked them at all. I really like the original MB Quart and the now German meistro. They are fkn awesome. I don't car what any JB hifi sales assistant says.
Fk especially hooked up with the Rockford 360.
Man memories of sitting In the car for hours tuning with the laptop
I dig my Type R splits. You do have to stage them properly though - not speakers you can really be facing away from. My Type S sub does alright for what it is too, anymore and my 17 year old car would rattle to pieces.
JL amps are very good value for money. They made a name for a reason!
I'm pretty sure they basically made a knock off of JBL audio lol..
And me being an OCD audio guy, I can't stand the poor projection of the alpine range especially the harshness of them.. I can understand the value for money thing, but poor sound actually gives me a headache. You can blame mark for making me notice thing I probably would never have noticed before lol
I don't think Alpine count as value for money, except for maybe Type S stuff. They are more "get what you pay for" and sit in the medium cost range. It's not high end stuff but it's no JB HiFi combo sale package either. Fortunately all my gear came with my car.
If I was doing a system again in a decent car I'd hit up Boston/Rockford/Focal. Do it once do it properly!
/audiolinesaustralia (cwatididthere?)
Yeh that aswell, but why would you spend money on good support for shit speakers?
Being in audio you figure out how to make everything sound it's best. Whatever the position or setup be, or limited to..
Plus the better the speaker in most cases the less you have to worry about volume measured boxes or ported.. Or even the position they're in.
6x9 should never have been invented. Waste of time and money. The ones in my car annoyed me so much that I unplugged them lol
But focal/Rockford/German meistro.. All these you really don't have to worry about the position as they project substantially better than alpine shit.
My opinion anyway everyone likes different tunes, I prefer the warmer sound, where some actually like the middy sort of stuff.
I believe you get a lot better sound per dollar value in spending on setup than speaker models.
Put in the research and time and your average speaker models could sound as good as your higher end models if their setup is done poorly.
I've recently built a decware deathbox II enclosure. Haven't tested it yet though. However it's all wired up.
Anyone have a 1ohm stable amp for me to test?
I have a feeling mine might be 1ohm stable....
Will need to check, I used to be into car audio a few years go but not anymore. I can't even remember the model of the amp :/
At the moment its 1200wrms @ 2ohm for my sub
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
