oh my bad didn't read that properly, well you'll see my brother at Goodlife! drives a 33gtst
Matt was just trolling around all over the place
Edited by UNR33L
You'll see me and Birds down there then :P
No he won't, we're Genesis fool.
Ahahaha. Too bad, could've learned from you 'masters' ;p
On the issue I was talking at before, looks like I'll probs get my order cancelled and refunded... had a quick read of the site's ToC's (unless they were just updated haha... but doubtful) - and it more or less covers them in cases like this.
So I guess the answer is it depends on the site/company's ToC... basically I think most will have ToC's that state your 'purchase' is rather an 'offer to purchase' until confirmed (and may also have a separate clause for pricing errors) - and they are within rights to not sell it to you (I believe after they have sold it to you, it's too late unless they have some other clause).
Mmmhm. Sadly probably no $9 suits for me hahah.
Went for a ride out the track?
Yep sure did, almost threw up by the time we got back, not a good idea to not drink anything until 2pm and then go 180kmh around a track on a hot day!
Sure was, too busy lolling @ the R Motorsport GTR in the parking lot.
who you go for a ride with that was that slow?
Someone who couldn't put his foot down in 4th without running out of fuel pressure, mother f**ker :P
If he felt sick after laps with me... Imagine him with you or paul or richo....
So apparently there are cars called the Mitsubishi Lancer Evolution VII and I have heard a rumour that they don't handle very well around corners....
I decided to take it apon myself to do some research and document my findings in a short film that I like to call "Sandown Session one Lap one Turn two, How embarressment!"
I didn't puke, so all was good :)
Okay, so he's at least turning through corner 1 now...just gotta work on corner 2 and so on until he's familiar with the layout :P
LOL as if I was, fixing my hair maybe - nohomo
but yes I was there, were you one of the drunk dudes hugging a dude peeing? lol
I was the guy to your right blowing his nose.
You wouldn't have seen me as you were captivated in your reflection
hahaha fair enough, should of said hi! how'd you go on poker anyway?
Wasn't really sure if it was you so yeah
I wasn't playing, just went there to meet up with my mate who was...I played a few hands with his uncles cash when he went for a piss and finished up, so I went well if you count that lol
The suspensions completely f**ked now. Strut tops have completely torn out and grease is coming out of them :S
Tyre pressure was way too low.
Even John Richo drove it and is it was hard to drive.. Guess I gotta learn it abit better
Me two haha. I am not a good passenger. Went in a 500hp 996 Turbo for instructors lap
Even taking laps slower than my own driving I felt like throwing up.
So no more passenger laps for the rest of the day!
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
