Jonoe, you work at the carwash in Altona/Yarraville?
Near the westgate entrace right? Saw your car parked on the gravel....
I had a magnetic taxi sign that lit up through 12 volt / cigarette. Think it came from eBay.
Had a yellow mazda6 and friends bought me one, magnetic but used batteries.
A while ago, I think his English name was Darren
real name is Chong Hwa Meng
Story of accident
http://ondscene.my/k...ua-rempuh-tiang
Fucking hell!
I am guessing he couldn't handle it and lost it while turning?
Wasteland move so fast, cbf keeping up.
LOL!
Fkn lol. Relevant to a couple people here who met him / had him over for dinner at their house...
http://www.skylinesaustralia.com/forums/topic/418077-patrick-hamilton-a-warning/
That's so bad.. But why has he never gotten in real trouble for shit like that?
I'm sure someone will stomp his teeth into a gutter for takin a snap of the wrong girl
Well talking about things doesn't really have means for getting into trouble, and what you do O/S is just that...
So ye, not much trouble to get into really.
He already got in trouble, it's only just clicked to me actually. A long time ago I remember him saying that he lost custody over his kid cause the cops found child porn on his computer and he said someone else framed him or used his computer themselves to look it up...starting not to believe that one now.
He also got pulled over roadside for a routine search through his laptop for illegal porn...
Tipping he'll be in jail soon enough. He reminds me of my ex-friend who goes to Asian countries and acts like a complete tool taking advantage of being a westerner over there and thinking he's king shit.
Yeh I guess . What a freak show..
How's the business goin?
haha ye pretty much!
Good, opening will be mid Feb sometime, we should be in there end of Jan to start setting up once fitout is complete etc. Will do a soft launch over a week for family/friends and then go the larger opening week etc. Cant wait to get in there really and start doing it
We got approval for a Facebook page so will have a few offers for people and what not:
https://www.facebook.com/SquiresNunawading
just the horrible inconvenience of a gearbox on his doorstep that he will have to move.... OH NOES
does he wear a bintang singlet?
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
