Just relocate a spider...good chance you won't ever see it again let alone it bite you.
Hell I inadvertently saved the white tail that bit me :/
Had I known it was him responsible for the weeks of pain that followed, I probably would have stomped him. Those f**kers pursue things to bite, not out of defence.
It's already dead. Drowned it in outdoor strength baygon. Any other insect I will put outside but spiders I just cannot handle..
Hundsmands I leave them alone as I know they don't bite. Daddy long legs.. Eh.
But the white tails red backs f**king whatever colour. I will kill them, and I will run
Dat azn squat...
Seriously how the fk do you balance?!
I can do this...with a fair bit of weight across the back of my neck...but I do have 1/8th Chinese blood in me, so figures...
Did you read latest newsletter?
Yes :(
What were you looking for there?
Was there for coilovers, the R needs low and ended up booking it in with Shockworks for new coilovers after riding in Brett from Shockworks 34 Sedan.
your car.. lol
hurry up and buy an evo.
LOL Aaron, you're cheeky... And spotted Sunkist at Mitcham Coles car park.
He's Asian!
SAU newsletter? If so, yes!
Some Friday watching
The vids bring the lol's and so true at the same time.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
