What happened to all the casual cruises that used to be on?
yea i went to my first one with turbodragon (andrew) well the pre meet anyway at a petrol station next to a car wash.
mine and his where the only skylines out of about 6-7 cars. i bailed. wasnt impressed.
met a dude with a lancer, new version. some older guy in a merc. adn cant remember the rest. i ended up ditching and heading home.
i had 10-15 or so skylines rock up to the first one i organised. i also remember one meet at monash uni that was just meant to be wasteland whores that turned out close to 30 cars. casual meets are not much point these days
Yeah, YEAH!
Back in the day meetups!
was that in mordialloc? cause I was at one with an old dude in a merc and he was a cockmunch
haha. talking about nurburgring and shit? and then he stopped when he realised i lived there. haha! yup.... that would have been the one!
tall well built dude had a lancer too. i only rememebr him cos i asked if it was a ralliart cos of body kit and it wasnt.
I also have other extensive mods... including a ralliart gear knob...
I got one of those as well.
Had it in my Bluebird as I got it for free.
only issue was it had a 6 speed pattern on it and mine weas a 5.
couple ppl who drive it nearly did a Sunkist
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
