Is that the plate your getting ?
Don't answer my question with a question. I want answer man. NAO!
Also for reference... car is gonna be satin black with chrome meisters with mehbe Gold spokes... might end up with black spokes tho... depends if my mate can come through with powdercoating it gold.
well the plate is ghey (sorry brah :wub:) if it has to be though its black an gold all the way
NB: only if gold on rims otherwise its pointless having gold on the plate
Edited by alr33x
Ugh... gold is $100 more than white? WTF? $650 for a set of plates? I could buy a turbo upgrade kit from the US for that.
So don't even bother with the custom plates, just buy turbo kit!
Today's new purchases...
R230 Diff
Nismo RS521 LSD Disc Kit (12kgf/m)
Nissan Diff Side Seals... $5.33 each from Japan, vs $36 each from Brighton Nissan :|
*prays it all arrives and I can get it all together before deca* Single spinning with a shagged diff is no fun...
R230 Diff
PM me price brah
Im thinking of getting one as well
Speaking of number plates, are we able to just replace a single plate with the slimline one?
Just want a slimline for the front.
Yep, just ask vicroads to change a plate to slimline.
Tell me more about how you managed to fit DOUCHEBAG on a numberplate.
douchebag.
I think you need to order a pair of slimlines so then have 2 full sets and just rock one of each.
Edit: Oh is that all Grant? I gotta get me one then!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
