number 1 on the list just for Ham
http://jalopnik.com/...shole-123108858
lolfags
Bros...
Srs help needed. Have to choose the colour of the plates for teh Golfen-wagen by the end of today...
White on black like Rodney King...
Or Gold on Black like dat nga Jay-Z...
white on black as you ahve said you want to take them from car to car... duh
might have to raise the R.. :(
I think I need more camber in the front and cant get any without replacing the upper control arms.. but dont want to spend heaps on the Ikeya ones and the cusco ones say 'Skyline: Only 2WD Vehicles (GT-R Excluded)', not sure the whiteline kit will give me enough camber at the height im at also..
The upper arms are the same across the board. They're listed for R's as well.
http://www.rhdjapan....34-wgnc34-16650
Can see the only model variant not under the 1 part number is the N1 GTR.
Send Chris an email at Racepace, we have our own little set that we put on, can't tell you price unfortunately but I know they're competitive and some of the best you can get.
hrmm thats interesting!
wonder what rhdjapan are on about then..
I might do that, thanks mate!
I hope competitive with the cusco's and not the Ikeyas :P
is this what you looking for?
http://justjap.com/store/product.php?productid=17665&cat=&page=1
Anthony, Perfectrun have them cheaper than RHD
http://perfectrun.jp/src/detail.php?pid=35008&pname=FRONT%20NEGATIVE%20UPPER%20ARM&maker=CUSCO&maker_id=35&result_mode=pmk
$325 shipped
Or you can get them from Yahoo Japan for cheaper still.
http://page15.auctions.yahoo.co.jp/jp/auction/t287739855
Add 1k for Streeter/% for IM etc commission and whatever postage will end up being and they're still pretty cheap
I still don't get what its about after having it explained to me..
Seems to be the latest fad which will die away in a month or so
In other news:
Police shoot at hoons in Southeast
http://www.heraldsun...b-1226576662880
Haha cos shooting bullets at something that's at least 1.5 tonnes hurtling at you will stop it. Hope he aimed at the driver, cos shooting tyres at an oncoming car is almost impossible.
In other news:
What an idiot... Nothing to do with hoon behaviour though, it's about complete f'ing retard behaviour.
If the cop had time to draw his weapon and fire at the front of the vehicle, surely he'd have time to get out of the way instead?
I doubt he was TRYING to run over the cop, he was just trying to get him to move out of the way...
Mythbusters taught me this a while ago
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
