number 1 on the list just for Ham
http://jalopnik.com/...shole-123108858
lolfags
Bros...
Srs help needed. Have to choose the colour of the plates for teh Golfen-wagen by the end of today...
White on black like Rodney King...
Or Gold on Black like dat nga Jay-Z...
white on black as you ahve said you want to take them from car to car... duh
might have to raise the R.. :(
I think I need more camber in the front and cant get any without replacing the upper control arms.. but dont want to spend heaps on the Ikeya ones and the cusco ones say 'Skyline: Only 2WD Vehicles (GT-R Excluded)', not sure the whiteline kit will give me enough camber at the height im at also..
The upper arms are the same across the board. They're listed for R's as well.
http://www.rhdjapan....34-wgnc34-16650
Can see the only model variant not under the 1 part number is the N1 GTR.
Send Chris an email at Racepace, we have our own little set that we put on, can't tell you price unfortunately but I know they're competitive and some of the best you can get.
hrmm thats interesting!
wonder what rhdjapan are on about then..
I might do that, thanks mate!
I hope competitive with the cusco's and not the Ikeyas :P
is this what you looking for?
http://justjap.com/store/product.php?productid=17665&cat=&page=1
Anthony, Perfectrun have them cheaper than RHD
http://perfectrun.jp/src/detail.php?pid=35008&pname=FRONT%20NEGATIVE%20UPPER%20ARM&maker=CUSCO&maker_id=35&result_mode=pmk
$325 shipped
Or you can get them from Yahoo Japan for cheaper still.
http://page15.auctions.yahoo.co.jp/jp/auction/t287739855
Add 1k for Streeter/% for IM etc commission and whatever postage will end up being and they're still pretty cheap
I still don't get what its about after having it explained to me..
Seems to be the latest fad which will die away in a month or so
In other news:
Police shoot at hoons in Southeast
http://www.heraldsun...b-1226576662880
Haha cos shooting bullets at something that's at least 1.5 tonnes hurtling at you will stop it. Hope he aimed at the driver, cos shooting tyres at an oncoming car is almost impossible.
In other news:
What an idiot... Nothing to do with hoon behaviour though, it's about complete f'ing retard behaviour.
If the cop had time to draw his weapon and fire at the front of the vehicle, surely he'd have time to get out of the way instead?
I doubt he was TRYING to run over the cop, he was just trying to get him to move out of the way...
Mythbusters taught me this a while ago
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
