at least chatruese doesnt burn... pure alcohol? itd be like metho with delayed vomiting.
when in NZ a bartender offered me his 'under the counter' bottle of absinthe. said it was 85%. had a shot and 5 seconds later my stomach was like nup. walked to the toilet casually and vomited it all up.
http://gizmodo.com/5984476/meteorite-crashes-in-russia-panic-spreads
Fuarkkk
"What's more incredible: unconfirmed reports say that an air defense unit fired a missile as the meteor entered Russian airspace at supersonic speeds, shattering it to pieces."
Thats fkn mad. What happened if that shit happened to aus. Dont think we got no air defence units. Hahhaa.
f**ken just went to renew my passport as the old one full.
So frequent traveler passport with priority processing.
there goes $500 WTF
Bill it to work. If you can't afford passport, they can't send you overseas lol
company policy is that they don't refund passport
same as eg Aaron not refunded for drivers lic
am pushing for an exception tho
Lol so tell them you can only afford the standard rate. If they want priority they pay haha
http://gizmodo.com/5...a-panic-spreads
Fuarkkk
yeah i just watched all these videos of that.. pretty amazing!
didn't know they fired a missile at it! but I'm guessing there is no way a missile could of even caught it..
if it did.. wow.
lol in aus our air defense is just to throw other rocks at it
if it did.. wow.
Can't find a google image, but I am reminded of the Simpsons episode where the Australians throw cans of beer at the helicopter...and a throwing stick.
that throwing stick stunt of yours has boomeranged on us!
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
