i could watch take off videos of the Antonov AN-255 on repeat for days..
sure there is all that trust from their engines.. but f**k its huge..
I always liked the il76 at canberra take off
http://youtube.com/8hdx3L1PSNM
if i had the choice between cars and planes it would be planes for sure
i'd buy me one of these bad boys in a heartbeat
unfortunately I don't have $2 mil odd to spend on my hobby :/
Could always sell your first born
yeah that's what one of my mates does,
He drove to darwin once and outback QLD about 6 times last year as well as NSW and such.
unless he has back to back jobs drives every-where, big Diesel 4x4 with cruise would make it relaxed.
only flys when it OS even then I recon he would prefer to tow a tinny and risk it.
So if work get their way
in next 6 months will be doing
USA
greece
Kuwait
Germany
Germany second time
finish just in time for honey moon to europe.
that said think Kuwait won't happen...well hoping.
I wanna a go in jetski.
+1
they disturbed a LOT of people last night
+1
Picked up my missus and rushed to St Kilda sat by the bay with heaps other people. Was contemplating whether to get ice-cream but was scared that we'll miss it. Waiting, waiting, waiting, waiting, waiting........ waits and then decides to check fb and saw the cancellation.
Not happy Jane! But ice-cream and seeing the penguins made up for it. lol
Lol
Thanks everyone for the Wedding Congrats
Here's a proper video of the day:
http://vimeo.com/60318071
Awesome video. Outstanding effort to get it all shot and editted in one day. They even included reception footage before showing the final video 1hr later!
I like the bit where my r32 is visible in the background :D
was meant to be a c130 doing a fly over on stkilda beach releasing angel flares:
however at the absoulte last miute they post someting on their facebook page saying that there has been a technical difficulty with the plane and that anoter c130 could not be organised, but if you wanted to see it then just go to the airshow.
what do we have like 1 c130 in vic and that's it?
IMHO it was a stunt designed to get people to pay to go to the airshow and was never going to happen.
I'd bet they never even got the appropriate permission to deploy the flares
Interesting theory.
Were you waiting for it too? Got to the end of the pier before we'd heard theyd cancelled. Everyone just sat around to enjoy the scenery anyway, and it was an amazing sunset.
Some navy dude was sent out to tell us it had been canned, and said the plane had taken off, they noticed something not right, landed and had a look and apparently it was much worse than they thought. (doesnt make sense choronologically, but whatever)
I reckon its funny because it highlights the lack of maintenance and tight-budget priorities of the defence forces you hear about. and also that it was supposed to be a celebration of the longest service record of any aircraft in RAAF history, is that a good thing? lol
I wouldn't say no to a free plane / boat / jetski
screw buying one you'd use it like 3 times a year, give me a dirt bike instead :D
birds get a dirt bike and all your jetski faggotness will disapear, real men crash on dirt not on water :D
Edited by UNR33L
don't get me wrong, they're okay.. but how much bang for buck do you really get out of them? can't see them being used much here in melbournes shitty weather..
on another note:
anyone coming to the chasers dyno day this saturday? I'll be there to check out some cars / run mine on the dyno!
Edited by UNR33L
Shitty weather? You scared of getting wet on a jetski? Better get the rust proofing paint if you ever buy one :P
on another note:
This coming from someone with experience on Jet Skis right?
nah bro scared of the cold :(
LOOOOOOOOOOOOOOOOOOOOOOOOOOL (couple of days old now but cant stop laughing when i see it hahaha)
http://www.youtube.com/watch?v=cpfQSqfpuac
Edited by UNR33L
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
