This. You normally upgrade the fuel system capacity when considering an E conversion, which takes care of everything being new...cept the fuel lines (which should be fine as long as they're not crumbling away).
But I has gtr fuel pump :(
Damn it, ethanol tune hey.
Someone tell me how far I can get with 550cc injectors
SO media blasting results:
hmm we need to fit a master cly...lets just hit it with a hammer hard them bog over the dents.
that smooth as rear quater:
quality door:
but when whole rear quaters skins are 56$ it's all fixable...
What brand?
I made it to 330rwkw at 92% duty on nismo 555cc
but most people have run out of flow much lower (thinking nismo 555's are just the 740's painted a different coulour)
Drop am rb26 in an drift on a mountain against some yakuza punk. Do it
lol
you should totally do that man... with the appropriate ethnically diverse group of ambitious 20 somethings it will only take you 1 night including paint!
lol
But then a GTR owner somewhere will be missing his engine...
lol
The best part was ignoring the S15 they could have used instead...
The Mona Lisa if you will...
Also re: the e85 evos, I thought he meant that was happening WITH upgraded 1000cc+ injectors and fuel pump.
Edited by kaitoukid
The only reason the evos pop on e85, is because tuners like to cram timing in downlow.. The rods can't handle to much low end torque..
Burnzy has said out of all the 7's he has tuned on e85 only one popped, because of something completely different.. Ie waste gate or something
glasses are annoying, wake up, can barely see clock / find your phone, have to take them off at the beach / swimming cant look at womens or see mates / throw balls n shit, have to clean them all the time, can't play footy, can't wear sunnies, look like an idiot at 3d movies, can't see shit on roller coasters with no glasses, fog up in shower or heat, can fall off during sex, annoying to get motorbike helmet on, can't take semen to the face, have to get special wider goggles when I was doing motorcross the list goes on, can't motorboat things
Contact Lenses :)
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
