Scott and his deflating my tyres to 27psi warm.
Squirming tyres felt like water haha even Richo drove it and thought something was f**ked. And yep, 27psi did that
Lol my first track day at sandown when it was wet found out later my tyres were 26psi
Yeah we used all your studs. Was still one short. Had to use a bolt :/
Fitted the apexi intercooler. So epic. No reo cutting, no front bar cutting. Mounting Brackets lined up with factory holes. Pipes slid into position with no f**king around.
Shame they stopped making intercooler kits.
However in the process had to lose my factory options. No more auto spoiler and lost a fog light :(
Good to hear! Now you can start winning races :D
Just got an offer for $1500 for the pink S14. might take it. Anyone else want a track use only S14 for moar than $1500? Needs a wheel bearing and manual conversion
My first question would of been - why is it pink
ex queen st car. nuff said. they had cut the numbers out to do some dodgy shit and they had this perfectly good pink car left behind. basically bought it to make a track car, but then it lived in the back of my garage for like 5 years cos of skyline, golf, 240z and a heap of other cars being more fun to do shit with. Now I need to get my garage space back and I need it gone.
Can't be regged... ever... cos it doesn't have a VIN, and it's pink because of some mohomolebos in Syd.
2 get da chix wet cuz
Same colour. even had similarly mohomo chrome wheels that I told em to keep. Mine's a Series 1 (one in the pic is is a series 2). Wouldn't be surprised if this was the car that they used the VIN numbers for. Goddamn dodgy f**ks.
Haha soon...
I hope there will be no surprises when Trent tunes it. Car is hunting pretty bad now. Might have to check over the injectors, turbo, intercooler install
but richo didn't crash it right?
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
