Vettel bout as popular right now with the Aussies as stingrays around the time of Irwin's death
Yeah pretty f**ked up what he did.
felt a bit sorry for rosberg not being able to push either, but that's team strategies!
Poor kimi got no luck with traction also..
Well as drivers on teams, they know that the individual race stops before the actual race finish. He was just frustrated and wanted to prove a point, but chose the wrong time to do it. Disobey team orders = selfish glory hog. You have the whole rest of the race to get out in front and decide the podiums...after that it's team strategy. Don't think Vettel played football as a kid...if he did, he would have been a striker lol
Was changing sparkplugs in dad's Bmw, put two out of four ignition coils wrong way. Started car up and wasn't happy.
Looked at the ecu fault codes and it said "cylinder 3 and 4 misfire"
Dat german technology, knowing exactly which cylinder is misfiring.
Something like that would be great for skyline coil pack troubleshooting
/coolstorybro
just reading through the Vic Time Attack regs and was wondering why its so expensive for race entry? $600 for open class, yet $300 for street. Theres no prize money, but theres a number of sponsors. Surely a $5 entry fee for spectators would help fund an event like that
that's easy
because time attack
same as when motive tried to start theirs the prioce was massive..and wondered why hardly any-one entered.
Funny how everyone that cried murder when Ferrari used team orders is now pissing and moaning because vettel ignored team orders that influenced the race result.
Now Now I'll laug while those same muppets try to tell me how its not the same etc etc.
but dezz, it's just not the same
meh f1.
seconded.
Cooking a roast last night was just as exciting. The carrots and potatoes finished before the meat was done. Its always a gamble with how much longer it was going to take, cant have the vegies getting cold.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
