If Judge Judy has taught me anything, its that stupid people somemtimes do stupid things with some kind of backstory.
Cousins aunties step-brothers mothers dog probably borrowed money a while back, or stepped on someones shoe or called someone a slag.
Anyway point is, if there was some sort of personal involvement or the victim recognised them from kindergarten or if it was some sort of vigilantism (sp) the news/police report isnt going to mention it.
Forced break-in of elderly lady? sure, probably pretty straight forward.
Man stabbed in a supposed mugging and the muggers not taking anything and then being caught within 24 hours? theres probably more to this.
This is a good point...
When a relative of mine was jailed, I couldn't believe how many media reports came out spruiking absolute bullshit - facts and statistics wrong; writing only one side of the story; changing words around to suit; misquoting etc. Completely lost faith in the mainstream media at that point. Focus seems to be on getting the story out there and grabbing attention rather than telling it how it is. Sensationalism defined.
Can do, are you gonna be running an aftermarket oil cooler though? If you are it might pay to delete the factory heat exchanger while the engine is out. NA heater hoses clean it up a lot under the plenum and gets rid of a heap of potential leak points.
So I see, no aftermarket oil cooler yet unfortunately :(
Where did you get that pic from? One of your jobs? Looks very less cluttered than my stock one
@@Birds
when we had a shooting near the club, the herald sun ran a FRONT PAGE article saying the shooting happened inside Hard Kandy. They included our name, logo, a photo of people on the dancefloor and a floor plan of the clubthat was complete with little stars showing where shots were fired and where the fight broke out.
the shooting was unrelated to HK and actually happened at the exford which is on the other side of the road and has nothing to du with HK. It also happened over 30 minutes after we kicked the group out of our club for being overly drunk and abusive.
still the herald sun just made up a headline grabbing story and there was nothing we could do as once the paper was run, the damage was done.
we contacted our lawyers (a HUGE international firm) and were told that there is no point pursuing it as the herald sun make a habit of doing this and has the means and finances to defend the issue for a lot longer than we do
cliffs notes: herald sun has no integrity and I would like release a pack of ebola monkeys into the building and lock the doors / windows
Here's the part #'s for R34 heater hoses, rad hoses, thermostat & heater core.
Upper Rad Hose - 21501-AA000
Lower Rad Hose - 21503-AA000
Heater Hose Core Upper - 92401-AA000
Heater Hose Core Lower - 92410-AA000
Metal heater hose piece on firewall - 92403-AA000
Heater hose upper - 92400-AA500
Heater hose lower - 92412-AA500
All The Hoses for the heat exchanger
14056-21U20
14053-21U10
14056-21U10
21307-21U20
21307-21U15
Thermostat - 21200-V7205
Heater Core assembly - 27140-15U00
If you have the opportunity to do an aftermarket oil cooler it would save a bunch of effort and be better for your engine in the long run, These are the parts needed for heat exchanger delete which then get rid of the upper and lower heater hoses and all the heat exchanger hoses as well.
Fitting between pressure sender and block - 25071-F6000
Front Heater hose - 92412-70T00
Rear heater hose - 92400-70T00
Threaded piece for oil filter - 15213-21001
Block fitting for Rear heater hose - 14075-75T00
@@Birds
All of them have no integrity as far as I'm concerned. The moment something becomes more about ratings and money than truth, corruption has a path. There's more to everything, which is why we're never in a good position to judge based on news alone. Even experts disagree!
A friend of mine did work experience and confirmed what we already knew: working for the herals sun requires selling your soul.
And unfortunately, I work with people who read the shit. I do know poeple who read it, just so they can point out all the errors and how misleading the stories are, which is almost just as bad.
Offloading responsibility onto others is quite possibly the best way to get through life without a hitch. I believe they teach courses on it, but they call it a diploma of management.
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
