I'm only friends with one, and just as a hi how are you if I ran into her, otherwise f**k that. I have enough respect for my current gf than to be running around talking to my exes.
It is only possible to be friends with your ex if the relationship was a stupid idea in the first place. Don't try and tell me otherwise birds lol.
It's good that you were able to cut ties, but you gotta be able to stick to it, sometimes the easier way of sticking to it is to just rebound, or constantly go out with mates, it will show u that you don't need her, and will piss her off as well when she figures you don't need her.
And if you two end up getting back together, just be aware that it will be a very different relationship and will probably not last that long.
+ 1 to that
Hang out with your mates, talk to new girls, get back into your hobbies. Once you find a new girl you will soon forget about your ex, and think back what an idiot you were for trying to get back with her
the way I see it there are 2 options...
1) break contact... Don't text, don't reply to texts, dont answer calls, and do NOT drunk dial. do absolutely nothing. There is nothing they hate more than this. You can move on or not, she will never know, and this will hurt the most... for the longest time. she doesn't deserve your contact. This is probably the easiest on you aswell.
2) if you are really pissed about it.... and i mean reeeeeealy pissed.. ask to try again...be the best god damned boyfreind in the universe so she HAS to take you back... then when she is asleep inject her with a little heroin each night... a little bit more each night untill she starts to get sick when she wakes up... THEN tell her what you did, leave and refer to option 1
  • Like 1
Thread on BB got deleted by cliffs:
- Brah found out his GF was cheating
- Made her shakes before he found out, he added in weight gainer and she unknowingly consumed an extra 1,000 calories a day
- The results after 4 weeks:
Thread coulda been fake but still had a laugh
staying friends is more often than not a bad idea, unless you were good friends before you got together.
I miss the friendship I had with my ex, she was pretty much my best mate, but it wouldn't be possible to stay friends as we weren't friends before we got together and there will always be some feelings there
Have you ever been in a long term with a friend?
Once you take it that one step further the friendship goes away.. And that's the chance you take by dating them.
How long were you friends for?
And was it a close friend or acquaintance?
And how did the situation come up? Did she one night say I want some cawk?
it's Friday spill the beans I need entertainment
Agree with dezz...if you had friendship beforehand then there can be something worth salvaging. It's tough but eventually you do lose the feelings, the same way a chick friendzones a guy. Don't think that cutting ties is always the answer too...some people do that and the day they see their ex again, bam, all the feelings come back. Like going cold turkey on an addiction and then having just one cigarette or trip to the pokies. But most of the time it is the best way to do things.
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
    • OK, now we are ready to get started. You need to remove the air boxes on each side for clearance. The cover is straightforward, undo the clips on the top and lift the front cover out of the rest of the housing. If it is tight you can remove the air filters first. The rear section of the airbox is trickier. On each side you need to remove the Air flow meter wiring which is held to the airbox with a clip; you need to get behind the clip on 2 sides if you want to remove it without breaking it - unclip the harder side and pull on the clip with medium force, then unclip the easier side and it should pop out The airbox is held onto the intake hose with a spring clamp; you need to get a flat bladed screwdriver behind the spring on both sides and pop them outwards. When you have got them in the right unclipped place they will stay there and the airbox slips out pretty freely. Put a rag in the intake to prevent anything getting dropped in there, and also to prevent you seeing that the turbo seal is leaking oil (as they do). Then. The top of the radiator is held by a steel plate, it is secured by 2x10mm and 2x12mm headed bolts . Remove them and remove the plate Also grab the bushings that hold the radiator to the plate on each side so they are not lost!
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
