With all these people thinking there's a meet tonight...someone is gonna turn up to GC alone lol
Should we be getting kebabs anyway? I'm not liking the weather at the moment for standing outside a van or shop.
Welded diffs are gay, chuck a GTR 1.5way in with new clutches.
is this coming from opinion or experience?
either way i have no job so not buying anything....
I had one in the ke70... Was fine, just need to be aware of compression lock. I wouldn't do I in anything other than a drift car tho
compression lock is fun :D
i though i read they were good for track too...or am i getting muddled up...
1.5 is better for circuit. It will be locked when you are on the boil, locked when you are on hard overrun, but unlocked the rest of the time which makes for much better cornering as you don't get forced under steer.
2 way is better for drift because it is always locked unless clutched in, so it's the most predictable
Weldy is just always locked... But I got the ksev around car parks etc no real worries.
1.5 is by far the best option if you have a car that isn't drift specific
Basically with my Nismo 1.5 way, even in a 300+ rwkw car I could drive it as hard as i wanted in all possible scenarios without ever having to give consideration to how the diff will react. And that in itself is worth every penny
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
