Also im on the e85 is annoying bandwagon...its fun and the power is nice ..but leave it sit I your tank for a month then try start your car and it is f**ked...took me 15-20 minutes to get it to fire the other day..i'd stick with it for track though im flicking back to pulp for street o ly because my car sits for weeks sometimes
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
