It is with great sadness to report that I have accepted a new job in Perth and will be moving permanently.
I will commence work by end of July so the next sauvic meet will be my last :(
It has been a big decision but it seems to be the right choice to develop my career.
I will miss you all brothers :(
Thanks for all the memories & laughs.
/4 weeks and counting until judgement day
f**k! Congrats man!! Should definitely organize a proper send off
Wow! Congrats anyway man
its coming across, only the weak sell up!
/tilldeathdouspart
I've heard perth isn't as strict in mods so you can go a bit crazy on 32 :P
Picked my Desmonds up from Import Monster today
Makes me sad I;m selling straight away though
yeh think Josh's GTR has like 350awkw or something, used to have more AFAIK but had problems and needed to rebuild again
either way, duno how a 200kw falcon could beat it hamish your mate must be an idiot lol
has cams so sounds mad as well
yeah pretty much.. he's more of an associate really...
he's got a couple of mates with FPV GS's and for some reason the fact that they have nearly 400rwkw and he goes cruising with them means his car is all of a sudden unbeatable
every other day he's posting things about his drag race conquests on f/b that I don't believe.
he did mention the car was making a lot of "noise" which would be the cams.
ahh and maou is over, by far my fav series of this season.
im putting off watching the last ep. all the action episodes are so generic... domestic disputes and comedy are what the show does best.
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
    • Item 10: Tech Edge wideband sensor interface and display. You’ll need to buy a new sensor. $150. Item 11: part of a Willians 5 point harness. $40 Item 12: OS88 gear display. No need for it now, my PPG sequential came with one. $30
    • I took it out, even though I knew I probably don't know what I'm doing other than looking for power signal lol. Lesson learned here I guess, even if it looks normal, worth checking as it only takes a few seconds anyhow. And maybe disconnect the battery, even though really shouldn't have to.
