If you ran that trap speed with no cage in a jap car there is NO chance they would let you run again
nah it's just heathcote don't care, calder will tell you to slow down then boot you off at anything over like 130 or 140 i think
Hey Martin; you do a lot of traveling...
Thinking of buying a new laptop to use when onsite & on transit (planes, airport lounges etc)
Asus Taichi 31 - tablet / laptop hybrid ; easy to play with on transit
http://www.asus.com/Notebooks_Ultrabooks/TAICHI_31/
Alienware 14 - most powerful 14" laptop ; more usability when onsite or at home
http://www.dell.com/au/p/alienware-14/pd?oc=w510772au&model_id=alienware-14
Laptop will be my only system at home, transit & on-site.
Better to get a laptop with more power to use at home/onsite or a laptop which is easier to use during transit etc?
Any other suggestions would be great! Although dont want to spend more than $2k
yes they put you in groups.
they will ask for any experience when you say none they will look at the car and pick a group.
Auto Manual Stag will be in one of the slowest ones.
Just do the next SAU VIC track day Huy
At least you'll be driving with alot of familiar faces
And less chance of a random spinning out in an emo.
hmmm.... you guys think I'll be fine with stock breaks? 1 hard lap then 1 cool down lap in each run?
Think I might stick to deca this year before a tune and brake upgrade.
Don't buy a netbook. You'll just want to head->desk repeatedly.
Although that said, I'm a fan of the PC at home, and if going down route of home pc+laptop; laptops are fairly affordable these days and should be able to get a decent i5 etc. Haswell is out now too, so.
I'll probably buy an ultrabook of some sort next sem.
Always gotta weigh up performance vs cost vs portability... but $2K budget seems plenty to get best of all three aspects.
I've heard some good things about LBO horize ones which you can customize too. But name brands are around for a reason too :P
/Nothelpful
If you want to use on the move get a 13 inch ultra book
Personally I'm looking to move to a Samsung ultra book myself
If you need more power/ screen than an ultra book at home get a tablet and a home system separate
And no idea why ppl think I travel much!!!!!
They do Alienware stuff now anyway.
this. reason alone not to get Alienware.
Dell is probs best for cheap laptops because of "customer service" and no lack of spares. in the end, it's a laptop, it'll be a POS in 2 years no matter how good care you take of it (unless it sits dormant and doesn't have new things installed)
speaking of travel, 4:45 wake-up call for 7:45 flight yay. only going to Sydney though, so not as exciting. f**king swear flights to Fuji would have been cheaper *grumble*
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
