He has also stated that in Scott's original, the viewer had trouble working out which characters were robots (replicants) and in his version the viewer "will definately be aware which characters are robots"
You know what that spells right? origin story yayyyy. Dark backstory, add some hatred for replicants with a garnish of disaster porn and you have Blade Runner 2: Apocalypse
Drove my first Porsche (only a cayman) today. Very low to the ground with small windscreen. Cockpit feels very similar to the s2k.
The PDK gearbox was cool, it rev matched on deceleration & gears changed without feeling anything
Handled quite well and suspension was firm. Could only imagine how much fun it would be with a proper engine :P
I did like the engine being behind, did sound nice when I gave it some poke
Still not as good as the R32 right? :P
It's a new day... still mad...
“The original movie was great in the 80s, but try watching it now next to movies like Attack of the Clones and The Last Airbender, and it really does feel lacking by today’s standards.”
When asked about casting, Bay’s keeping tight-lipped for now, although sources inside Hollywood say both Shia Leboeuf and Will Smith are in callbacks for the part of Rick Deckard, while Chris Tucker and Nicholas Cage have both been hinted at for the part of sadistic Replicant, Roy Batty (expected to be renamed: Roy Barry).
Asked how he plans to update the characters: “In the original, the robot characters really didn’t look or act much like robots – due to a lack of CGI options in the 80s. So you really had to use your imagination there. That was the first thing I wanted to address, and while I can’t give much away yet, lets just say you’re gonna know the robots in this movie are robots from the 21st century!”
Michael Bay – whose film credits include such groundbreaking works as Bad Boys (1995), The Island (2005), and Transformers (2007) – is no stranger to the sci-fi genre. He was reportedly first choice of Warner Brothers president, Alan F. Horn, from a shortlist of directors including Ridley Scott, Chris Nolan and Andrei Zvyagintsev.
/RAGEQUIT
hey victorians. thought id ask again... anybody have a pair of 235 40 18's laying around gathering dust? i need a cheep (relatively) pair for my spares...
hell ill take 245's.
please and thank you.
What about soft compound race semis? :)
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
