why the change in heart Matt? usually people sell daily GTRs for something a bit more subtle.
I'm more of a 33 GTR man anyway, I'd get one of those, like Anthonys, but well out of my price bracket at this stage.
why would anyone let go of a gt-r?
Why don't you buy it brah
because they break a lot and parts are expensive.
This is true to a degree, this one hasn't cost me a lot, clutch was the most expensive past and that's it, nothing else has gone wrong with it. Although I have seen what a lemon GTR can cost and I'm very glad mine's not.
My stress levels went down 1000% after selling my GTR lol
So stressed about cops/breaking stuff on it and putting down thousands on it :( still was a fun ass car though.
Edited by UNR33L
You hipsters will slag me off but fun for cheap mid to late 90's sti. I loved mine.
Pity, we don't get to see one of these often.
Only garden variety WRX sold here...
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
