17x8 235/45/17
17x9 255/40/17
But you know this already and you're probably outside my house about to pick them up by now...
Edit: He was outside about 30 seconds after I posted this ^
SAU Brah's helpin each other out yo
das good he's sorted.
unless rwc guy wants stockies, then...
text me if he still needs them.
If rwc guy wants stockies... then he needs to find another rwc guy, because that's got nothing to do with the Road Worthy Requirements...
Considering the RWC legislation in relation to rims/tyres states that the track width of a car cannot exceed 100mm and that R34 rims are 17x7.5? and 225mm tyre. Good luck with your RWC goals of 2013
I called him before because I thought I was being spammed. He's in hospital with some sort of serious chronic flu, was causing him to have seizures and black out n stuff. He's getting better, he's just bored now
Had a discussion with couple of mates earlier, they assured me it won't be the case.
But I'll see how I go tomorrow.
Shit.
Get well soon Hamish.
Aussie citizens stuck in an escalating conflict.
How to get out and come back?
Dads in syria with his mum. grandmas on her death bed but he may have to get out of there pretty fkn soon...
f**king arabs.
Your fault Aayayron, you must be the carrier... :P
Hey guys... Still in hospital with enchiphitis (viral menengitis)
Basically it's an inflammation of your spinal fluid and the fluid around the brain. It keeps expanding and squashes your brain.... Feels like your head is in a vice :/
Neurosurgeon reckons I was just unlucky.
Had a lumbar puncture, something close to 100 blood tests, a couple of MRI's, 6 CAT scans, X-rays, if antibiotics and morphine 4 times daily since Saturday.
Had a seizure on Sunday and didn't know what year it was / couldn't speak properly.
Should be out in a week if all goes well!
Da fuq??
Its something you probably haven't heard of /hipsterhamish
Get well soon brah.
Going from a 17x7.5+40 to a 17x9+38 you only get an additional 20mm of poke either side, so 40mm is plenty legal.
Sheeeit, feel better soon hamish
f**king arabs.
Fek! I hope he gets out ok
Whoops sorry
tyre/rim combo must not exceed 15mm sorry. End of the day depends how much of a kent the RWC guy is
Also get better Hamish!
AHHH Hambo that sucks :(
meningitis is some serious shit. get well soon big guy.
thanks guys.
looking at the bigger picture. I hope the us stands down and a possible ww3 is averted.. shits getting really heated
woah.. thats some pretty scary stuff.
hope you get well soon man.
finding out if import monster have any TE37SL's in stock and if they do I'm going to try and get my deposit back from tyrepower hawthorn and go out and buy some straight away, I'm so over waiting and being stuffed around.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
