I still cant get over A45 250kw from a factory 2L.
the day draws nearer when the pulsar can have its arse-handed to it by production hatches and will be the slow 70's hatch equivalent of today
It's wont happen with the reliability of Mercs it wouldn't be able to chomp a pulsar if it's on the back of an isuzu truck
Hmm have you sat in the back before? The front seats are awesome.
Back....okay at best....I wouldn't say roomy lol.
Lol it's not that bad man, even my coupe has a fair bit of leg room in the back..
2009-2010 depending on condition go from 70k to 90k..
2011-2012 go from $110 - $130k.
You want? There's a prestige auction coming up in belmore soon. There's a nice handful of them in there
link me to 70-90k amg c63 they must have high kms or be farked?
guys. clutch talk.
car will have around 300rwkw and will mostly be a week end car, sometimes drive it to work since its close etc.
I what is a decent clutch that wont break the bank? id love a nismo twin plate but yeah nah lol
would want it to be nice to drive and be able to take a beating when I track it..
its boiling down to buying the little things to finish it now :)
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
